I ordered the three repair kits for the WD62725 TV. I was having a "34" code and the local service provider said I needed a Format, signal, and power board. I replaced all of the caps provided in the kits. When I put everything back together, I turned the TV on and the screen is snowy and then after about 30 seconds it shuts off with a blinking green light. I unplugged the TV and did a system reset. The blinking green light stopped. I then did a Menu/Device simultaneously and got a "12" error code which according to the service manual is "no problem found" message. Am I missing something here? Your help is appreciated.
  • 73 Answers
The problem is with your e2p board.It is no longer available so you need to send yours to mitsubishi to be reprogrammed.
Posted on Jul 01, 2010
  • 8,617 Answers
Most likely a wire plug connection between the boards or where you unplugged one, as the code 12 means there isnt any errors with the set, so its almost certainly a wire connection double check the ribbon cables extra good.
Posted on Jun 22, 2009
My 2005 WD62725 just started getting wavy lines on it. Everything works good (i have picture and sound and all functions) but the lines started first only when a non-HD signal was coming in. Now it has...
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Dead,has 3-blinks
I just had repair person out for this same issue on my 960. Three blinks indicates overvoltage from power supply. Two transisters have gone bad in the power regulation circuitry. Since it is such a common prioblem these parts are on back order from Sony for at least 10 days. Price of repair including in home service = $318.
Apr 28, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light for bulb indicator stays on.
You need the V26 DLP power PWB repair kit. You can get it at the following link under the repair kit category and it has complete instructions with the replacement capacitors.
Jan 15, 2009 | Mitsubishi WD-62526 Projection TV
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Converting my TV
Yore in luck if you already watch TV from a cable provider you will not have any problems when "The big Change" comes next February
Feb 19, 2008 | Televison & Video
WD62725 Lamp
code 34 is lamp abnormlality which what you are discribing is most likly the balast, since the lamp comes on for a brief second then shuts down. the part # 939P978010
Jan 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
