Question about Plumbing
Leaking outdoor hose bib
I have an outside hose bib that is leaking. I just moved into my house so I can't tell you mutch about the plumbing. I noticed that when I turn on the water I could hear what sounded like water spraying against the wall inside the house. I put a hose on the bib and blocked the end and I noticed that there was water running out of an opening in the brick about 1 foot to the right of the hose bib. I removed the screws that hold the valve in place on the wall and pulled the pipe out about 2 inches. Again I turned the water on with the end of the hose blocked. Water ran out of the opening in the wall where the pipe comes through. It only does this when the valve on the bib is open. If I close the vale, all the water stops. I do not see a leak where the valve is connected to the copper pipe coming out of the wall. If the pipe had a hole in it, wouldn't it leak all the time? I am confused as to where the leak is and why it only leaks when the bib valve is open. Any advice would be appreciated.
  • fnlyfree Jun 22, 2009
    One more question. My house is on a slab foundation. I can only pull the pipe about 2 inches out past the brick on the outside. Opposite of the pipe is one of my closets. I assume that I would have to cut a hole in the drywall and access the pipe that way. Is this correct?
  • 21 Answers
Ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Posted on Jun 21, 2009
  • Cameron loker Jun 23, 2009
    that is correct .  what you can do to hide the hole is cut a hole the same size as an heating grate.  then when the work is done put a heating grate there if it happen again easy fix.
Where are the shut off valve to cut the water off
Should be on top of the water heater cold water supply.
Feb 23, 2015 | Water Water Heaters
No i don't just trying to help a elderly lady
It's not the sprinkler. The valve is not seating completely. You will notice the sprinkler it is leaking from is the lowest one in that particular zone. Don't take it out on the sprinkler it's not his fault. Think of it as if you didn't shut a hose bib off completely the leak doesn't drip at the bib it shows up at the end of the garden hose. Same principal. The valve is the hose bib.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
Cant get hose bib off pipe for leak replacement?
Follow it through to the inside and replace the length of pipe complete from rising main to the outside tap.
or
They are normally soldered on, so you need a blow torch.
You probably only needed a 5 cent washer, or gland packing in the top.
Dec 12, 2017 | Plumbing
2.5 RUUD AC not working, power must be getting to the unit.
Have them turn the outdoor unit off and wait a few minutes. When they turn it back on they should here
the fan and the compressor come on. They are to different sounds.
If they think that they have both come on, tell them to check the black insulated suction line. it should at least cold to the touch. If not it could be a freon issue.
If the line does get cold, have them checkthe filter in the house. If that is ok tell them to turn the power off
to the outside unit. Take a garden hose and wash
the outside coils on the outdoor unit,be carefull not to
smash the fins. Wash them at an angle from top to bottom.
Jul 05, 2010 | Ruud Central System Air Conditioner
Leaking outside faucet on side of house . It's leaking where the handle enters tube that goes into house. Is it easy to replace the inside part and will that fix the problem?
It's pretty hard to tell exactly what you mean. A faucet on the side of the house is called a Hose Bib. There are several different kinds. Maybe you can do a Google Image search and find the kind you have. You might also find clues on how to fix it. If you give me some more info I can probably help you.
May 20, 2010 | Plumbing
The motor works fine , no pressure out of hte hose, could it be the hose or pump, how do I trouble shoot. Also, how do I draw soap from a bottle to shoot out of the washer onto the house?
Since you did not mention the pump brand or type. I will just assume it to be a pressure washer, complete
with gun. The pump comes two suction hoses. One for the water supply and one for the soap bottle or pail There is pressure adjuster right at the pump near where the hose is connected. You can adjust to higher pressure by turning it clockwise. You can adjust the nozzle spray pattern by turning it. However, if your pump comes with only one set of suction hose. Then, it is designed to get the water
supply from the faucet with hose bib. The only one
set of hose is for the soap bottle or pail. It will **** the soap once the nozzle spray is opened.
hose,
Jun 30, 2009 | Plumbing
Have b & K frost free antisiphon hose bib that leaks out of seal
You can replace with any brand frost free faucet.Parts are impossible to get.
Jun 14, 2009 | B&K Plumbing
Leaking outside frost free hose bib
take it apart and put some trflon tape on the threads
Jun 01, 2009 | B&K Mueller/B & K 450-032 90 Red Brass...
Plumbing Logo
1,045 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
