Question about Kenmore 72822Gas Dryer
Gas dryer will not heat up kenmore 80 series heavy duty 72822
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
I have a Kenmore 80 series heavy duty dryer that is not giving out much heat.What should I be looking for to solve the problem?
Is it gas or electrric? Either one i would check the dryer vent hoses. Check the lint trap as well. The lint trp is the exit for the hot air to circulate. Sometimes if clogged with lint these dryers could go either way they could over heat and cause a fire or cause the element or thermostat to fail. The electric dryers have a thermostat and a heating element. Those tend to go bad. Back panel should be taken off and unplug unit check.
Apr 03, 2011 | Kenmore Dryers
Dryer is a Kenmore Heavy Duty 80 series electric. Runs fine but very little , and often, no heat. Is the element gone?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Kenmore 72822Gas Dryer Logo
339 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
