Question about GoVideo VR3845 DVD Recorder/VCR
Recently installed cable from Optimum can't record on Go Video Rc
This Thursday I switched fro regular TV to cable with Optimum.
I am Not able to set up recording a program as I did before. Help!
Thanks
Giuseppe
5 Suggested Answers
  • 55 Answers
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Posted on Jan 16, 2009
Mike258
  • 1498 Answers
SOURCE: Recently, i;ve been trying to record tv programs
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Posted on Aug 17, 2009
SOURCE: CAN'T RECORD ON DEMAND MOVIES
panasonic dvd recorder model dmr es 15 records Comcast on Demand programs. I use it. it's an older model so you probably have to get it on eBay.
Posted on May 12, 2010
SOURCE: Sony DVD Recorder RDR-HXD990 will not timer record.
DVD wont consitently read discs drops out even though no scratches on discs
Posted on Aug 14, 2010
How to connect DAV-HDX265 to xbox 360 and TV
Your HDMI cable handles both audio and video. If you would like a "one" source output you need to have a reciever that has multiple inputs with one output. You would then put your audio out from your souce device (xbox, tuner,record player...etc.) to the input of the reciever. Every device should have a different input. From there you would just switch your input selection to what you would like to hear. Let me know if you need a bit more guidance and I will get more detailed. The RCA connection (Red and White) are your stereo leads or (left and right) You will need the yellow one for video..it is separate.
Jan 19, 2013 | Sony DAVHDX265 System
We have a Philips DVD3460 recorder. Where in the manual does it inform us on while Watching T.V. and DVD is recording another T.V. channel?. Would love to know " how to do this"?
It depends on your setup.
Think of the Philips DVD3460 as an independent, standalone television set. It has its own analogue tuner, and its own video input.
If you have an analogue RF TV signal (coaxial cable) going in to the Philips DVD3460, you can watch whatever you want on any other TV connected to the TV signal coaxial cable, since the regular analog TV cable carries all of the channels.
However, if you are using a cable or satellite box and use the "Video in" function of the DVD recorder or just have the DVD recorder tuned to channel 3 or 4 to record from a cable or satellite box, you can't record one channel and watch another unless you have a second cable box..
Apr 24, 2011 | Audio Players & Recorders
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Video settings
There really is no generic "Optimum Settings"... It basically comes down to what looks good to YOU. If you really want to get it as close to the original source recording as possible, get a movie like "Fantasia 2000" that has the THX video optimizer. The disc has a series of tests and procedures to help you configure the video settings for the most accurate picture.
Sep 12, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Audio is out of sync with video
what are the connections supported on your pioneer player? i suggest try to isolate problem, change the type of cables, like RCA or HDMI cables.
Jan 24, 2007 | Samsung DVD-R130 DVD Recorder
GoVideo VR3845 DVD Recorder/VCR Logo
74 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
