The printer printed a copy of advertising but when I try to print my document it says the printer is offline
  • 4 more comments
  • florenceelli Jun 21, 2009
    I tried everything but unplugging and it did not work so I will try that now
    Just tnhought you might have wondered where I got to, be back soon
  • florenceelli Jun 22, 2009
    Sorry that did not work either it just keeps saying the printer is offline
    The printer is a 460 canon pixma is that whatyou need to know
    I am running windows vista
    I will check again in the morning thanks
    Thanks for your help but I don'r feel comfortable updating things, I think I will take the printer to repairman then he can worry about messing up
    Thanks again Florence
    I just thought I would tell you I found out what was wrong with the printer
    The box that comes up when you press print, it shows the number of copies etc and
    also the printer, well I had the wrong printer showing-I had canon 460-1 instead of
    canon 460 pixma .
    Just another one of my dumb mistakes, but it may help you in the future
    Thank you Florence
  • 10,594 Answers
I think you get advertising page by self test of printer that does not requires connection with computer.
Please make sure USB or serial cable are connected with printer and computer properly.
Install printer software/ driver CD in computer, restart computer and try printing now.
In case of problem, shut down computer, unplug printer and computer from AC outlet for couple of minutes, reboot them and check printing.
Thanks.
Posted on Jun 21, 2009
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Jun 21, 2009
    Please intimate printer model and brand, what Windows is running in computer as well.
    Thanks.
    Shahid Electronics Jun 22, 2009
    That message means there is no communication between printer and computer.
    Are these connected with USB wire? Replace it another one and use other USB port in computer so computer will recognize printer.
    Another option is to uninstall printer software from computer and reinstall that software.
    Are you running Windows XP or Vista in computer?
    You can check driver update for this printer at Canon Support.
    Thanks.
    Yes, Please update printer driver of Vista from above Canon support.
    Thanks.
    No Problem,
    Good Luck.
    canon 460 pixma .
    Thank you Florence
    Wow, so it was wrong selection of default printer in computer.
    Thanks to let me know that.
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Windows 7x64, HP8000, Offline
Disconnect the printer.
Click Start
Click Control Panel
Click Printers
How many "copies" of the same printer are installed?
Delete them all
Connect the printer, and let Windows "add printer".
Jul 18, 2010 | HP Office Equipment & Supplies
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
Jan 15, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Same Problem - Printer Says Offline
try reinstalling all drivers,, and cancell all prints. before.. take an test print from , control panel ---printer-- print a test page..
Sep 27, 2009 | Brother MFC-410CN All-In-One InkJet...
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
Whenever i try to print something my printer prints a copy of something that i printed a month ago. I am having trouble printing something that I click on, the printer keeps saying that the printer is...
Delete any previous document, then click on control panel. then go to printers and other hardware, then go to printers and faxes, right click on the printer icon, then click where it says set as default printer, click where it says printer offlline and your problem is be solved!
Dec 03, 2008 | Office Equipment & Supplies
60 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
