Question about HP Compaq FP5315 15" LCD Monitor
Monitor blinks My monitor goes black and the power light blinks. I have to unplug it to get it to stop. Some times it will not stop.
  • tattoo Nov 03, 2007
    It's an hp pavilion vf 15
    I don't Know what the manufacturer is but it's an hp pavilion vf15 I don't know if this helps or not.
    I have a big monitor I hook up to the computer and it works fine I just don't like it. So it must be my monitor has gone bad correct!
Call the manufacturer. this monitor if mad by hyundai, which believe it is, is poorly mad and my customers have had many problems with them
Posted on Nov 03, 2007
Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Apr 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Dell LCD Monor light keeps blinking green, screen is black cannot stop blinking unless unplugged from power source but upon plugging back in monitor starts blinking green again
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Dell E173FP 17" LCD Monitor
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor Went Black
It sounds like the monitor might be going bad. I would try hooking up another computer to it. If it works with another computer, then I would say the Video card might be going bad.
Mar 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
HP Compaq FP5315 15" LCD Monitor Logo
178 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
