Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I HAVE A MITSUBISHI DIAMOND SERIES TV. I REPLACED
I HAVE A MITSUBISHI DIAMOND SERIES TV. I REPLACED THE CAPACITORS ON THE BRAIN LAST YEAR BECAUSE I HAD THE "BLINKING GREEN LIGHT OF DEATH." IT WAS WORKING GREAT, BUT NOW WHEN I GO TO TURN IT ON, THE SAME LIGHT BLINKS FOR ABOUT 90 SECONDS THEN IT TURNS ON, OR SOMETIMES I HAVE TO RESET THE TV AND WAIT FOR THE BLINKING LIGHT TO STOP, THEN I CAN TURN IT ON. IT TURNS ON, BUT IT IS A BIT ANNOYING TO HAVE TO WAIT FOR THE LIGHT TO STOP FLASHING. ANY HELP?
  • Steve Yocum May 11, 2010
    What were the location of the caps?
  • 64 Answers
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
Posted on Aug 01, 2009
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Jan 14, 2011 | Mitsubishi CS-27205 TV
Intermitent Shot Off
Please check the sleep timer is off..
Sep 23, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
My Mitsubishi diamond series 65" tv will not power on. all i get is a flashing green light on the timer button.
Try replaceing the DM capacitors that often cures that symptom. You can get the V26 DM repair kit from www.tvrepairworld.com the kit also contains the CD with detailed instructions.
Jan 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv will not turn on, the timmer light keeps flashing, mitsubishi diamond
These are famous for bad capacitors in the DM module. The DM module is basically the system control or brain box for the set. This can be a tricky repair. You should really have a shop check it for you. Thanks for using fixya.
Nov 11, 2009 | Televison & Video
THE GREEN LIGHT IS BLINKING ALL THE TIME
You have the one that the capacitors go bad on, this set is the most complicated set to work on call the pro's but expect as heafty bill, the chassis has to be pulled out and sent into Mitsubishi for a rebuild.
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Diamond model WS-65813 The system light (on light) blinks fast. The System Reset button has no effect. Unpluging & pluging the set in has no effet. Then, for no known reason it starts...
After plugging the TV in, it normally takes about two minutes for the processor to boot before the light will stop blinking and the TV will turn on.
Sep 08, 2009 | Mitsubishi Televison & Video
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
I have a mitsubishi DLP big screen TV where timer keeps blinking continuously after I have unplugged and plugged in and TV wont turn on.
THERE IS NO NEED TO REPLACE THE BRAIN. THE CAPACITORS THAT ARE NEEDED TO REPAIR THIS PROBLEM CAN BE PURCHASED FROM RADIO SHACK. I REPLACED THE 4 CAPACITORS THAT ARE LOCATED INSIDE THE BRAIN, AND I FIXED IT IN 30 MINUTES, COST OF $8. IT HAS BEEN WORKING GREAT FOR OVER ONE YEAR SINCE.
Nov 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
197 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
