Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
I need a truster speed for a Minn Kota Endura 46
I need a truster speed for a Minn Kota Endura 46 ; 3 or 5 speed foward , 2 back please send me a reply at claire.charette@ sympatico.ca.
P.S.if possible tell me , in Canada or in Quebec (or both) where to find the parts for that model.
  • 76 Answers
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Posted on Sep 26, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
Posted on May 13, 2009
SOURCE: how do I remove the composite shaft from the motor housing
I just replaced the shaft (composite) on my Endura 34 today. First, remove the crossbolt that attaches the control head to the top of the shaft. Second, remove the top cover of the control head. Third, make note of the wire connections within the control head (take a picture) and then unplug the red, yellow, white and black wires...no need to unplug the main 6 guage red and black power wires. Fourth, with the wires unplugged, pull the shaft with motor housing attached through the transom mount assembly. Fifth, immobilize the motor housing (gently vice?) and heat the socket in which the shaft screws into motor housing. Do not overheat, only use enough heat to soften factory sealant making unscrewing shaft possible. Sixth, reassemble in reverse order.
Notes: Do not use a pipe wrench as this will crush the composite shaft, either old or new. Apply thread sealant prior to installing new shaft (I used Permatex Thread Sealant/Formagasket). Ensure crossbolt hole on top of shaft aligns with motor housing below.
Posted on Jun 17, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn kota endura 55 is three years old is making a grinding noise when in operation..
    I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
    Cost me around $85 at the local marine mechanic...
    May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
    What spec battery is the best for the Minn Kota 40 Endura trolling motor?
    that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
    May 19, 2011 | Minn Kota Endura 40 Transom Mount Trolling...
    What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
    The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
    Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
    What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
    You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
    Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Trolling Motor specs
    call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
    Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Overheated Minn Kota Endura28
    This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
    May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Trolling Motor will not run
    Hi!
    For starters, here is a schematic:
    Endura 30
    Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
    You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
    Best of luck!
    Mike
    Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    238 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
