Question about Dometic RM2652 Refrigerator
Frig warm freezer works fine, refrigerator is warm whats wrong can you help me
    Sergeant:
    Champion:
  • 208 Answers
Unthaw the fridge ice is blocking air flow to the fridge section
Posted on Jun 21, 2009
I have the new RM3762 with the temp. readout on the door . Work great until it get to 90 to 98 outside and then it go to 50 in refrigerator. then at night it will go to 36. The fans on the coils are working.
Posted on Jun 24, 2009
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
Help my frig is dying! The freezer compartment is working fine-but the frig compatment is nit colloing at all! What is wrong?
If the freezer is working that is a good sign. Here are what might be the problems; 1) Ice build up in the freezer will block air flow to the refrigerator and thus causing it to get warm and stay warm. If you observed a build up of ice in the freezer, it means that your defrost heater and/or your defrost thermostat is bad. In any case, replace both.
2) The evaporator fan plays an important role in circulating cold air in both freezer and refrigerator compartment. Listen for the evaporator fan and make sure that is running. If you can hear it, it has gone bad and will have to be replaced.
3) if any of the above applies, the lower or upper air dampers may be obstructed. Check and make sure that they are open.
4) Too much food or stuff in the freezer may also be the culprit. If there is too much stuff in the freezer, you might want to remove some them to make way for air to flow in the refrigerator compartment.
I hope this will help solve the problem. Do not forget "Feedback"
Jacques
Mar 24, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
My frigidaire frig is warm but the freezer is working fine whats wrong
heatman101
Mar 15, 2011 | Refrigerators
Frig is warm, freezer is working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Maytag MFD2560HES Bottom Freezer French...
The engine is still running, but the frig is warm a friend turned the timer and the freezer is freezing now, but the frig is still warm. Do I need a new timer?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is working fine. The refrigerator is not
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
WHIRLPOOL side by side freezer works fine but frig warm
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Jan 20, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
333 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
