Question about Maytag MSD2732GR Side by Side Refrigerator
Comressor is too hot and there is ice bild up on the line
The compressor seems to run for a long period
  • 585 Answers
Remove the grille from the front of the unit beneath the doors and look at the condenser coils. Most people have no clue whatsoever that those must be cleaned periodically. If the airflow is choked off by excessive dirt, the system will overheat, and the performance suffers accordingly. Let it go too long and it's compressor time. Clean with what you have available, one of those polyester featherdusters along with a good vacuum cleaner with crevice attachment along with a dust mask for yourself is highly recommended You may also want to pull the unit away from the wall so to clean from the back as well. There should be a removable panel. While you're in there, make sure the condenser cooling fan is unobstructed and turns freely.
Posted on Jun 28, 2009
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Line seems to be blocked compressor running hot and other unit icing up model MUH17TN Mr. Slim 18000 BTU's
Most likely low on refrigerant, liquid line ( small pipe ) can frost up and indoor coil can start to ice up.
Sep 11, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
2003 Odyssey dual A/C Blows hot air front & back. High and low pressure compressor lines are hot. Is it feasible that the Air Mix Motor Assembly is the problem? If so, how do you check?
No the door would not be the problem. One AC line with the compressor running should be ice cold (large line) and the other line hot to the touch
Jun 25, 2012 | 2003 Honda Odyssey
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Motor is hot?
Which motor is hot...compressor or fan?
Also need to know the model number.
Is this a 3-phase or single-phase unit?
Let's assume it is the compressor...Is it so hot that you can't touch it for more than a second or two? Is the compressor shutting down on internal thermal overload?
Compressor body hot can be caused by a number of things:
1. Low charge (the freon acts as a coolant for the compressor).
2. Electrical imbalance (3-phase only). (check line-to-line voltages)
3. Bearings in compressor failing (check amp draw).
4. Condenser dirty or airflow blocked in some way.
5. Condenser fan(s) not running or running backwards.
6. If water cooled condenser then water flow problem.
Hope this helps you get started.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
The compressor is running but it doesn't seem to be circulating refrigerant
hi there....locate the high pressure pipe (small diameter pipe)...touch it by hand and feel is it cold....warm.....hot............
cold.......compressor running but no ressure......change comressor
warm.....compressor running....low in gas or internal gas leak..try recharging system may not be repairable
hot.....compressor running.....blocked system....usually not repairable
regards Sir Galahad
Aug 13, 2009 | Frigidaire FRT17G4B Top Freezer...
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Maytag MSD2732GR Side by Side Refrigerator Logo
134 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
