Standby light blinks 6 times
I have a Sony KDF55WF655 LCD projection and the unit will not turn on. The standby light flashes green and then to red with 6 blinks when trying to turn unit on. The redlight will continue to cycle red with the six blinks. Arox. one year ago this same thing happened and the repairman replaced a fuse. I have searched the large panel borads in the rear back corner of the unit and the only fuse I see is a glass fuse. If I remember right the item the repairman replaced was a wired fuse. Is this correct? Where do I need to look? New bulb does nothing as I have a spare.Thanks
  • hankl36 Nov 19, 2008
    I have the same exact problem. What is the solution?
    I have the same tv and the red light blinks 6 times then pauses then keeps doing the same thing. Do I just need to replace a fuse.
I had the same problem to, i replaced the thermal fuse and everything was back to normal. Be careful if you are a gamer because both times this has happened i was playing my xbox
Posted on Oct 30, 2009
If i turn on tv i here clicks and red light starts to flash 6 times in a row and just keeps flashing can i fix this my self ?
Hi, there are numerous flashing codes for these sets so I included a web page dedicated to the Sony flashing light and you can look the forum over and try and pinpoint the number of flashes and the related causes. I also included the cuase for the 6 blinks and this can be fixed if this is the only issue.
Usually, the problem resulting in 6 blinks, pause, 6 blinks, etc. is a defective thermal "fuse", which is actually a bimetalic temperature switch. You may find the "KDF55WF655 6 blinks/KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655, KDF60XS955" information package of value. See the "Frequently Asked Question for Sony Products" forum "Television Troubleshooting Infromation Packages" thread for more information.
Once you get to this site request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
I believe this fuse is right next to the light housing
http://www.agoraquest.com/searchbb.php?term=SONY%20KDF%2042WE655&addterms=all&forum=all&submit=1&sortby=p.post_time http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70 If you find this helpful a vote on the thumbs up would be greatly appreciated for this free advice and thanks for using Fix Ya
Aug 16, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Kdf55wf655 55 inch sony wega 6 blinking lred lights
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
May 30, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Nov 03, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
