Question about JVC Audio Players & Recorders
How to lift up the JVC L-a21 platter for changing the belt? Thank you in advance.
I am not familiar with this exact turntable, but on most belt driven turntables, the platter should simply pop off. There are usually holes in the platter once you remove the rubber mat. Put your fingers in the holes and pull up while pressing down on the center spindle, and the platter should pop off. Sometimes you have to put on a little force to get it to come off.
The holes in the platter are to allow you to attach the new belt to the motor spindle once you put the platter back on with the new belt.
Posted on Jun 21, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Turntable not rotating. What should I do?
    HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
    Jun 20, 2014 | JVC AL A158BK Turntable
    How to replace belt
    To replace a turntable drive belt.
    Before starting ensure you disconnect the power supply.
    1, Remove the rubber platter mat to expose the platter.
    2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
    5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
    6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
    7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correct operation.
    Remember, when changing between 33 & 45 rpm the platter must be rotating to ensure correct belt repositioning on motor pulley.
    Job done.
    Copyright, Styluscity.com
    May 05, 2013 | JVC AL A158BK Turntable
    Cannot get the platter cover off to change the belt on a l-a21 turn table . how do i do this?
    Unplug from the mains power & the amplifier phono socket
    To remove the plater: first remove the lid - then after securing the arm, FLIP the whole unit over onto the plater (perhaps resting it on your lap) then remove the all the black screws and the brass ones holding the rubber feet in place.
    Inside you will find a tube (actually the "pit" for the spindle) undo the (awkward) retaining screw on the tube. At this pint the spindle is now free and would otherwise slide out onto your lap, so just redo all the screws in reverse order -in particular don't forget the Earth wires.
    Then holding onto the turntable and plater - flip the unit back over.
    The plater will now lift out freely, taking care to unhook the belt from the drive capstan/motor (on the top left) keep hold of the belt with your two fingers (as you have already lifted off the slip matt ) let the old belt slip free and place the new one on the Flange remembering to hold with two fingers as before. the spindle will slide back into the "Pit" (ensure that the bearing has not fallen out) still holding the belt in place hook it over the capstan and under the speed changing device. Try rotating the plater a few times to ensure nothing is trapped untoward, then replace the slip matt.
    Re insert Phono lead and then mains power plug.
    Place side one of "Goodbye Yellow Brick Road" on turntable and enjoy :)
    Aug 04, 2010 | JVC AL A158BK Turntable
    How do I change a drive belt on my JVC L-A11 Turntable
    Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
    Dec 15, 2009 | JVC AL A158BK Turntable
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    Turntable drags. This is an old jvc, probably 16 years or so. Still works, but afraid the belt is stretched. Can we get replacement. Is this a dyi job? We are fairly handy. Betsy
    HELLO BETSY!
    It's pretty easy to change a belt on a turntable. Lift off the rubber mat and platter (the round part that turns) and you will see the motor on the deck. The platter has a rim underneath where the belt goes.
    The platter should have some holes in the top of it and this will help you to put the belt on to the motor pulley.
    First, put the belt on the rim of the platter. Hold the belt tightly through the hole in the platter and put it onto the centre spindle. Locate where the motor is and put the belt around the pulley - DONE!
    As for getting a belt any good hifi dealer/service centre or Radio Shack outlet should be able to help you - it is after all - only a rubber belt! (:-)
    Sep 05, 2009 | Audio Players & Recorders
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    JVC L-A21 turn table belt installation
    Lift the mat from the platter. Lift the platter off the spindle - it just pulls off upwards. Wrap the belt around the sub-platter underneath. If the belt is not stretched, it should stay there by friction as you replace the platter onto the spindle. Rotate the platter by hand until the motor pulley appears through the large hole on the front left hand side, and then gently pull the belt over the pulley, taking care not to twist it as you do so. Replace mat.
    Jan 24, 2009 | Audio Players & Recorders
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    467 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
