Question about Intermatic & Indoor/Outdoor Rain Tight Timer
How to wire intermatic timer 120 v - Intermatic & Indoor/Outdoor Rain Tight Timer
  • 760 Answers
You didn't indicate what model number. You can download a manual here:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Posted on Aug 10, 2010
I have the Paragon 4001-00 timer. The timer seems to be working okay as far as time and trippers are tripping however it doesnt seem to be engaging our secutiy door lock for the night. Could the conrt
Does the manual override lever move back and forth as trippers pass? If NO, then trippers are bad
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://www.amazon.com/dp/B00441YVCO/?tag=waterheaterti-20
120 Volt timer.
When timer is ON, test across terminals 2 and 3 for 120 Volt
If 2 and 3 show 120 volt, then timer is delivering power on schedule. Look for loose connections. Loose wire nuts.
If 2 and 3 do not show 120 Volt, then timer has failed.
Suggest buy T101 as replacement for durability and generic replacement parts.
http://waterheatertimer.org/Buy-T100-series-timers.html
Crossover wiring from Paragon 4001-00 to Intermatic T101
Paragon 1 to Intermatic 1, Paragon 2 to Intermatic 2, paragon 3 to Intermatic A
Nov 05, 2014 | Paragon 4001-00 24-hr Timer Control 120v...
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Pool timer
You have the T103 timer rated 120-240. The clock motor part of timer is 120Volt. This is a very versatile timer, but confusing for non-electrician and electrician alike.
Solve problem by converting timer from T103 to the 240V T104 by changing clock motor from 120V WG1570 to 240V WG1573.
Buy wg1573 clock motor at WW Grainger or drillspot etc.
Resources:
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
This simple fix is intentionally designed by Intermatic so their timers are not only adaptable to all electrical needs, but also can be maintained to last 25 years by replacing clock motors and trippers as needed
Jun 25, 2013 | Intermatic Hardware & Accessories
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Dec 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Mar 08, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
446 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
