Question about Whirlpool 24 in. ADG7952 Built-in Dishwasher
Whirlpool ADG 722 - can't re-connect new drain hose
Old drain hose was split - removed it ok from dishwasher- just pulled off (push fitting).
Purchased new replacement hose but could not re-fit.
Tried taking side panels off and front kick plate -
but no access to drain hose female push fit connection.
Best access is from small rectangular hole in back panel - but can't achieve sufficient force to engage it fully.
4 Suggested Answers
  • 246 Answers
SOURCE: Unable to fit new door panel to front of dishwasher
Im not sure what new panel you are trying. But if you can still get the old one back on, you can get different panels, color, and designs from applianceart.com. they also custom cut stainless panels to fit or they have a stainless foil that can cover the dishwasher. Black and white easily available too.
Posted on Apr 11, 2010
  • 557 Answers
SOURCE: Whirlpool dishwasher...Model 3385820, type #575-0..built-in...front
you can change that front panel, its not hard, personally i went to my local dump and took one off an old washer lol
Posted on Oct 20, 2010
  • 246 Answers
SOURCE: Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
I am not sure about which parts are required to fit the decor door but I do know of an easier option to change the look of your appliances. www.applianceart.com These guys have so many options and even stainless steel.
Posted on Feb 21, 2011
I need to replace the drain hose on my Samsung dishwasher as old one split but cant work out how to do it.
It's a big job. You have to pull the dishwasher all the way out. On most Samsung DW's, you then need to remove the metal panel on the left side of the DW to be able to get to the case-brake assembly. Remove the water inlet port on the inside of the dishwahser by turning it counter-clockwise ( a tool will be required). Pull the case-break assembly out so you can get to the clamp that holds the drain hose in place. Pull the clamp down and remove the hose. Have a towel or Sham-Wow ready to catch all the water. You will have to disengage the hose clamp at the back of the dishwasher, then you can pull the hose out. Reverse the process to install the new hose. As I said, it's a big job; if it sounds like more than you want to do, I recommend calling a professional repairman. Sears has technicians who are experienced with Samsung dishwashers.
Aug 12, 2014 | Samsung Dishwashers
I WANT TO REPLACE DRAIN HOSE WITH NEW ONE AS OLD ONE SPLIT
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
My dishwasher hose has 2 splits in it so I need to know how to replace the hose
remove the rear cover and loosen the hose clamp. Pull off the old hose. Put the hose clamp on the new hose, fit the hose to the machine and do up the clamp. Put the rear cover back on,
Dec 20, 2013 | Zanussi 24 in. ZDT6041 Built-in Dishwasher
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
Drain not draining
Elimination Of Problems From Most To Least Likely:
1. Connection from discharge hose to drain pipe is blocked/corroded.
a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting.
b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver.
c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection.
a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle.
b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c).
c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line.
3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely require removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
Sep 08, 2009 | Miele 24 in. G892SCU Plus Built-in...
The Dishwasher won't drain
Aug 08, 2009 | Kenmore Dishwashers
Replacing a drain hose
If you remove the steel left side panel you can see that the drain hose only extends a short way into the machine. Where the hose enters the pan is a white clip that has a small square hole this clip can either be removed by pushing on it from the inside or prying the small square hole with a screwdriver. the drain hose is held in place by a black triangular clip on the plastic drain loop simply pull the clip off and slide the drain hose down then pull it out from the back of the machine.
Dec 04, 2006 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Whirlpool 24 in. ADG7952 Built-in Dishwasher Logo
174 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
