Question about Cyberhome DVR 1600 DVD Recorder
Cyberhome1600 DVR Will not power up.
Bought Feb 18 2006 & after 15 months, finally went tech. Suspect PSU which after testing in situe for power, realised it was completely dead. I removed the PSU & no signs of overheating were present. 5 capacitors appeared suspect, 4 had popped tops, but not burst (2x2200mfd & 2x1000mfd all rated at 10volts) & 47mfd 400volt appeared to have had a slight leak. As the internal fuse was not damaged, would these capacitors have caused the 1600 DVR to have failed?
Would like to know if it is possible to repair it.
  • terence_otoo Jun 24, 2009
    Not sure yet, as I haven't replaced the suspected capacitors yet. If it dosen't work, I may try to adapt a power supply unit from a redundant PC.
  • 3,230 Answers
Yes these capacitors cause power failure and note these capacitors are need to be change.
the unit is repairable these all caps are not costly.
Good Luck!
Thanks
Posted on Jun 22, 2009
I turned on the TV and it popped and went off and will not come back on
Hi.
When that happens you have usually blown the PSU. The power supply is the board connected to the power cord. If there had been a pop sound, power went off, and now TV is completely off, then the PSU has blown.
There is a 6 Amp 125 VAC fuse in the AC section of the PSU, that is the first part to check.After that test the PSU. Sometimes it is even possible to spot a blown capacitor in the PSU board. They look bulged, sometimes burnt and in some case you can even see a leak. Sometimes is instead possible to see a burnt area that is revealing a short, often in the AC section of the PSU. The PSU is located at the back of the TV. Power must be disconnected before removing back panel. Do not touch PSU. Capacitors can store and release heavy discharge even with power cord not connected. There are also 3 small brown fuses located next to the flyback. Those can be tested using a multimeter. Testing must be done by a trained person.
The PSU cannot be easily replaced with a new one. The part is not in stock anymore (part number was 264102), and it is not even easy to find on Ebay. The PSU must be repaired.
Regards.
Ginko
May 24, 2011 | RCA HD52W59 HDTV Projection Television
DLP won't fire up...
Try first unplugging power cord, see if it reset.
Jul 26, 2008 | Samsung HLN437W 43" Rear Projection HDTV
MOTHERBOARD VIDEO PORT IS NOT WORKING BUT THE LCD IS POWER ON AND THE CPU IS ON BUT NO DISPLAY. WHAT IS THE PROBLEM ?
Hi check the monitor is working, next the check the RAM & CMOS battery or change, final add a addon Video Card and check
May 05, 2010 | Computers & Internet
I bought a hyndai in feb tucson. i can smell the exhaust
you may have an exhaust or manifold leak somewhere test it at a local shop
Sep 03, 2009 | 2001 Hyundai Santa Fe
PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
May 04, 2009 | MSI K8MM-V Motherboard
I am missing red color on my samsung 61" dlp tv
I bought this tv March of 2008, and Feb 2009 light engine went out, confirmed by TV repairman. Went through samsung directly.. WORST COMPANY EVER!!! No longer make this part, took 6 months to tell me that, after order went to 4 different repair companies. Finally, they offered $1770 to replace tv.. and weeks later, received a call that it was not approved so they offerred $1200. Still waiting for this check.. paid $2399 for this tv, still owe $1100!!! Samsung has worst customer service ever and do not stand behind their products. If you find replacement part for this tv, please post.. the part is expected to cost $850 and has to be professionally installed at $300.
Apr 09, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Ive had 6 blown subs in the last 6 months
be careful with fosgate amps. They are more powerful then what is stated on them. I found this out when I blew a 15 with a punch 260ix. These amps are made for competion use. The 600.1 does not push 600 watts as stated. I had one tested and it actually pushes close to 800 watts. Turn ur bass level and ur gain to about 3/4 power and this should solve your problem
Feb 23, 2009 | Car Audio & Video
Broken Power Supply
hello!
I guess that the computer have a one year warranty, You can claim a warranty anytime you want. But if has no warranty at all then you can repair the PSU by your own, Open the PSU and find any busted parts or maybe the fuse blownout that is very cheap you can replace that by your own. If afraid to do so, then let the repairman do it for you.
If no hastle it is recommended to by new PSU for your system.
Hope this help, best regards, melnavz
Feb 21, 2008 | Computers & Internet
Cyberhome DVR 1600 DVD Recorder Logo
103 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
