HI, you will need to check the following below to combat this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for LG WFT1071TP Top Load Washer
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to...
(More)
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to begin.
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes....
(More)
MY LG WASHING MACHINE WF-S6607TC SOON AFTER START WASHING IT STOPS THEN SPIN AND DRAIN LIGHTS COMES. AFTER READING THIS SITE I GOT TO KNOW THAT THERES A MAGNET ON THE TOP FRONT COVER. SO I BEGAN SEARCHING FOR THE MAGNET. BUT ITS GONE.. SO WAT ELSE CAN I DO?
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and...
(More)
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and once first part of cycle is in motion it over flow. Please send drawing of machine and where load sensor is located.
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need...
(More)
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need to rearrange the clothes or spin twice reducing the quantity to half.We do not over load the machine too. And some muck gets on the clothes from some part of machine. Please help.
