Question about Little Giant Submersible Fountain Pump
OASE fountain pump fluctuates height every other day.
My OASE fountain pump fluctuates height every other day. Day 1 it will be normal 3 inch height out of top of fountain. Day 2 it will shoot up 12 inches and arch to the side. If I turn off power and turn back on, it's normal. If I cycle power again, too high and arching. I can do this over and over. Are there two speeds withthis thing. Why does cycling the power change the motor? It is model OASE SP 500 G
  • 21 Answers
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Posted on Jun 24, 2009
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
How long will it take for water to evaporate from a pond
This depends on several factors, eg cloudiness, wind speed, and atmospheric humidity. An average answer for your data might be 10-12 mm per sq metre per day, giving 23 - 27 mm per day.
Jan 21, 2014 | Garden
How high does this pump example high high can fountain top be if pump is at bottom?
From the photo on the box, it looks like it will through a nice stream 4 to 6' high.
No details available though. Make sure the outlet of the pump is right at the water surface. You will need some rocks, bricks or a hidden floating platform to make it the right level.
If it is below water level, the fountain will be much smaller (may lose half of height for every inch below surface. 1" = 3 feet stream, 2" = 18 inch stream, ...
May 06, 2011 | Pontec Submersible Fountain Pump Sp 70g
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Aerate a pond
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
Dec 24, 2008 | Aquascape Designs Aquascape - AquaForce...
Sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Nov 02, 2008 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Little Giant Submersible Fountain Pump Logo
495 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
