Question about Whirlpool GS5SHAXN Side by Side Refrigerator
How do I change ice maker filter? - Whirlpool GS5SHAXN Side by Side Refrigerator
SOURCE:
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
shaggyrat
  • 1224 Answers
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Posted on May 15, 2008
  • 37 Answers
SOURCE: Ice maker not making ice
Make sure that the filter is the right one and that it is pushed in all the way. The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 03, 2009
aasc
  • 1606 Answers
SOURCE: water will not come into the ice maker
Replace the water inlet valve after making sure the tube which fills the icemaker is not frozen . If it is , replace the valve anyway . The valve is the piece which connects to the line to the wall on fridge .
Posted on Aug 04, 2009
BIKER T
  • 909 Answers
SOURCE: ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
Posted on May 23, 2010
Ice maker doesn't work after changing filter
The filter and the ice maker should not have anything to do with each other unless you raised the wire shut off on the ice maker and did not put it back down after changing the filter.
Apr 22, 2017 | Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker no longer making ice after changing filter,GE Eterna ESS25LG refrigerator
recheck filter install is water valve on and is ice maker itself on
Jul 24, 2016 | Refrigerators
Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Ice maker has ice in lower back part of ice maker, rotation stopd
you say ice in back of ice maker??? only the rear 2-3 cubes are filled??? adn the front 5 or so are empty??? then yes its possible low water pressure from a faulty filter can be an issue, shoudl be replaced at least every year. so you cant go wrong by changing it , at least rule it out!
Nov 22, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
ice bucket?
bin.
ice?
compartment.
(right) position.
REMEMBER:
maintained
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
21 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
