Question about Dell E771p 17" CRT Monitor
Monitor display My monitor display keeps shrinking horizontally.
  • Rainbow2008 Apr 02, 2008
    Up until about year ago 2 of my DAYTEKs started acting up with the screen shrinking horizontally and now my TTX is doing it too. I lightly tap the side of the monitor and everything goes back to normal. I find it is a magnetic field that is causing this. Maybe a badly grounded plug, I moved my TTX and I have a lot of equipment plugged on it at it's new location and it is doing it now too. I believe it is on the same circuit as my fridge. I haven't exactly pin pointed the problem. One monitor, if I replace it with a monitor that doesn't do it, will do it at the same location of the one that is doing it. It's something to do with what is connected on the same circuit of that outlet.
    Problem Solver:
  • 6 Answers
Im not too sure on how to fix the ungrounded curcit but upgradeing to a lCD panel would completly fix this problem.
Posted on Jun 06, 2008
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
Display Collapse
it is repairable but for the cost of parts and labor you would be better of getting a new 22" LCD monitor
for the problem I would suspect the fly-back transformer or power supply
thanks for rating
Jan 09, 2008 | NEC MultiSync FE1250 22" CRT Monitor
My acer monitor p244w has a clock setting on the menu.--what is this clock setting for?
The "clock" refers to the internal oscillator clock circuitry that is responsible for the generation of the video signals. It is NOT used to set the time on the monitor. It is used to make adjustments to how the display looks, usually stretching/shrinking the horizontal width.
Dec 30, 2009 | Acer Computers & Internet
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Minitor is shrinked on both side horizontally. The settings are all ok and resolution is perfect. Seem some problem with CRT or something like H/W. Any help on this???
Hi...there,
Open your on-screen display on your monitor, find & press auto adjust. If that doesn't work go to factory reset menu and pressed to reset to original settings.Then reboot your pc.
Jan 28, 2009 | SAMTRON 55V 15" CRT Monitor
Crt monitor problem
try to check the pincusion...
Jun 27, 2008 | AOC LM729 17" LCD Monitor
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
Mar 30, 2008 | LG Studioworks 775N 17" CRT Monitor
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
Dell E771p 17" CRT Monitor Logo
Alun Cox
