Question about Craftsman 25cc Gas Line Trimmer
What happens if you dont put oil in a weed ****? how do you fix it?
  • 40 Answers
Well, all the craftsman weedwackers that I have seen all have to have oil/gas mix. The owners manual will tell you how it needs to be mixed. Most are 40:1 You ask how to fix it so I guess did you start it and did it lock up? Let me kow and we'll go from there. If you haven't started it don't.
Posted on Jun 21, 2009
Ryobi electric hybrid weed eater quit working.
are there weeds stuck under the trimmer head causing it to work too hard perhaps and even short cords if not heavy enough will cause problems and burn out the motor
Jul 18, 2015 | Ryobi Lithium Ion 18 Volt 18v Cordless...
My yard machines weed wacker 4 stroke gear box overheats or very hard to turn. How do I fix that?
I would try putting some high quality gear oil in the box and see if that helps
Apr 25, 2014 | Yard Machines Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Do you add the oil first or the gas first?
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to know what kind of oil to put in my troy-bilt 4 cycle weed eater. I think the model num. is TB525CS, it's on the front of the weed eater right under 4 cycle.
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
May 30, 2011 | Troy Garden
Forgot to put oil in the gas for my trimmer and blower. will not start now. can this be fixed? how?
pour out all the gas and make up new batch you may have to replace the plug but otherwise your still in good shape
Sep 12, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Aug 09, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
254 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
