Question about Konica Minolta magicolor 2430 DL Laser Printer
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer will not function. Can you help?
  • nick193 Jun 22, 2009
    Thanks. That's helpful. Can you explain how I remove the fuser? The handbook is worse than useless. Thanks.
  • 58 Answers
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Posted on Jun 21, 2009
Konica Minolta Bizhub C353 wrinkles all papers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Nov 07, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
I HAVE A MEDIA JAM FUSER PROBLEM, WAHT CAN I DO TO FIX IT?
Well a media jam is a paper jam remove the paper. Remove the transfer belt or the fuser what ever is required. chk web site for owners manual. Self Help Product Support Konica Minolta Business Solutions Inc
Aug 25, 2011 | Minolta 2430DL Color Laser Printer
Media jam "fuser'
You need to clear any paper that is jammed inside. Then if you get the message after you clear the paper, check to see if it is a fuser problem.
Fuser problem:
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. if not then the fuser.
Here is the user guide, info is on page 89.
http://www.kn.nl/data/handleiding/174952/user%20guide_engels.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 04, 2009 | Konica Minolta magicolor 2430 DL Laser...
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Paper jam in fuser
Remove the right hand side cover of the printer, (loosen the two screws, one is at the back).... see the small stepper motor at the top right?
Rotate the white gear teeth connected to it, just visible, DOWNWARDS, ANTI CLOCKWISE, using a blunt screwdriver or something, a few teeth at a time, this will eventually rotate the fuser roller and the paper will come out of the bottom of the fuser.
Oct 25, 2008 | Konica Minolta Magicolor 2450 Printer
Media Jam - Fuser Error
if the paper comes out and you get still this message, then probably you have a wrong paper format or fusing unit solenoid is stuck.
Aug 09, 2008 | Minolta 2430DL Color Laser Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
779 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
