Question about GE Refrigerators
Temperature is set to 37 but refrigerator is freezing
    Sergeant:
  • 212 Answers
Replace your main cold control board and thermistor
Posted on Jun 21, 2009
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
We just started our new Sharp refrigerator (type: SJ-PT690R) yesterday evening after five hours of delivery. We set the temperature of the freezer & refrigerator at (-18 & 5) respectively. It is...
The fresh food compartment should be set to approx. 35 -37 degrees. Setting the fresh food compartment to a temperature below freezing does not compute and will not display an illogical reading. Adjust your settings according to your users manual and wait 24 hrs. before making any other adjustments
Oct 10, 2017 | Refrigerators
What's a good temp. setting for the food/beverage section
If you set the temperature below about 37 you run the risk of somethings freezing...but milk should be as close to 40 as possible, so I usually recommend a setting of about 39.
heatman101
Sep 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
The refrigerator freezes everything
Faulty thermostat. Replace or keep lowering temperature setting.
Jul 08, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
