Question about Electrical Supplies
We have a 4000watt portable generator, and it will not power up the RV as it used too? I would like to fix it myself, but do not know where to start. It won"t even seem to charge battery anymore muchless run a/c or minifridge. I was told awhile back that parts are interchangeable with Honda parts? jeff
  • sal sabea
    sal sabea May 11, 2010
    does generate power at all?
    Master:
  • 342 Answers
You will first off all need to check the output frequency which also indicates the speed the engine is running at
50hz 3000 rpm
60hz 3600 rpm
Posted on Apr 04, 2010
My yardworks 2150w portable generator wont start. Thought it was dirt or water in the gas cleaned it all up .not working. Lots of spark no start. Help
My yardworks portable generator 2150 won't start - Fixya
www.fixya.com/support/t14802132-yardworks_portable_generator_2150
Oct 28, 2012 - First check the circuit breakers on the control/outlet panel. Then take the end off the generator and look at the brushes (usually what breaks) and the ...
Why won't my portable generator start? - Home ...
diy.stackexchange.com/questions/.../why-wont-my-portable-generator-st...
Mar 6, 2013 - The generator is fairly new -- I bought it at the end of June '12. ... An E 3 spark plug is always a good start, Stabil (fuel stabilizer)in the fuel or ...
the generator in parts, accessories - Alberta - Kijiji
www.kijiji.ca > Alberta > cars & vehicles > RVs, campers, trailers KijijiLittle hours on this generator comes with command start was over $ 500 just for the starter. Yamaha ... Yard Works 2150w generator. Generator starts ... Wanted generator for my camper at least 1500 or more ... You won't see more new motorcycles at one place anywhere else. ... New Champion 4000watt portable generator.
Power Generators New ' Kijiji: Free Classifieds in Alberta ...
www.kijiji.ca/b-alberta/power-generators-new/k0l9003 Kijiji
Dec 18, 2015 | Electrical Supplies
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
I just recieved a Coleman Powermate 6250 watt generator. I want to know if it will pull my A/C in my RV
Im sure the manual will have the best application for that model, always best to read it first.
Mar 07, 2011 | Coleman Powermate Premium Plus 6250W...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Electrical Supplies Logo
104 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
