Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
I have a Moen L4600 lavoratory faucet and I want to replace the cartridge.(http://www.moen.com/shared/pdf/instruction_sheets/INS072F.pdf) I am having trouble removing the transition collar to get to the retaining clip. What is the best way to get that collar off? Thanks
  • 21 Answers
That is a good one you have to be careful not to mark the plating.  what I do is get some rubber or heavy cardboard and put it around the facet.  then I use my channel locks on the ring .  you have to be firm.  There is a tool called a strap wrench for this aplication but I never liked it much.  something like the one you would use to change an oil filter.
Posted on Jun 23, 2009
  • jddn May 30, 2011
    Plumbser -
    Can't figure this out even after reading your advice.
    Does the transition collar turn, or stay in place? Doesn't seem room for it to turn, and when I try it begins to move the whole cartridge too (so I'm probably doing the wrong thing??).
    What is the "ring" you put the channel locks around? http://www.moen.com/shared/pdf/l64600pt....
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
Moen 7700 cartridge replacement
This is the exploded view. The cartridge is available at any hardware store.
http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdf
Jul 08, 2014 | Moen Monticello Single-Handle Kitchen...
My cartridge is clogged
Here are two links to the exploded parts diagram and the installation instruction:
http://www.moen.com/shared/docs/exploded-parts-views/87499pt.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins10205.pdf
You may refer to them to take the cartridge out.
Feb 11, 2014 | Moen 87499SRS Harlon High Arc Kitchen...
I need a piping diagram for a Moen s3371 and a s3600 valve
http://www.moen.com/shared/docs/product-specifications/s3600sp.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins1281c.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3600pt.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3371pt.pdf
If you did your rough in for the hot water coming up from the left of the valve as you face the control and the cold on the right, that is traditionally correct.
Jan 15, 2012 | Moen Plumbing
Moen aberdeen #93980 manual
This is what Moen has to offer for the faucet itself:
http://www.moen.com/shared/docs/product-specifications/7592csp.pdf
The design guide is here:
http://www.moen.com/assets/moencom/images/design-planning/support/articles/kbplanningguide-revised8-26-09v2.pdf
The exploded view- for the 2 handle
http://www.moen.com/shared/docs/exploded-parts-views/7592cpt.pdf
The exploded view single handle. This is all that shows up for the Stainless model as well.
http://www.moen.com/shared/docs/exploded-parts-views/7590pt.pdf
The three other options/finishes have their own manuals
Chrome 2 handle
http://www.moen.com/shared/docs/instruction-sheets/ins802e.pdf
Chrome 1 handle
Bronze
http://www.moen.com/shared/docs/instruction-sheets/ins801k.pdf
Jan 07, 2012 | Plumbing
I lost the install instructions for my Moen 270 exact temp shower kit.
Moen Chrome ExactTemp Vertical Spa:
http://www.moen.com/moen/chrome-exacttemp-r-vertical-spa/_/R-CONSUMER%3ATS270
Product Specifications:
http://www.moen.com/shared/pdf/ts270sp.pdf
Exploded Parts View:
http://www.moen.com/shared/pdf/ts270pt.pdf
Replacement Parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=TS270
Unfortunately the installation Instruction Sheets/Owner's Manual are not posted for the 270 models. Suggest you contact Moen Consumer Support directly to make a request:
http://www.moen.com/consumer-support/contact-us
Apr 02, 2011 | Home
I need an instruction manual for a Moen Kitchen faucet model # 7570CSL
Do you need the installation guide or the parts list? All of the documentation is available at Moen, see: http://www.moen.com/search/product-specifications?fromTradeResource=true&search_terms=7570CSL .
The direct links are: installlation/owner's guide: http://www.moen.com/shared/pdf/instruction_sheets/ins1912a.pdf .
The parts diagram is here: http://www.moen.com/shared/pdf/ca7570pt.pdf .
There are several finishes for the 7570 from Moen. The instructions apply to all. The parts list will give the specifics for the parts that depend on the finish.
I hope this helps.
Mar 08, 2011 | Moen Plumbing
How do you get at the cartridges on the Moen 6510 faucet? Do the handles "pop' off?
Check out this link for instructions on how to replace a Moen Cartridge for your product.
http://www.moen.com/shared/pdf/6510pt.pdf
Hope this helps!
-Olivia from Moen
Dec 15, 2010 | Moen 2 Handle Lavatory With Drain Assembly...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
976 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
