Question about Briggs & Stratton Garden
Hard to start 18 hp briggs &stratton
Valves need adjusting, what is the settings?
  • 284 Answers
Cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Posted on Jun 21, 2009
I have 18 h,p briggs and stratton very hard to crank
First check state of the battery under a load must have 12.5 or greater if battery is good check the valve setting the can cause an engine to be hard to start the valves should be approx 6mm
Jun 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
26 hp brigg stranton, valve adjustments
yes but it is as simple as using a business card on both sides works just as well
Aug 17, 2012 | Briggs & Stratton Briggs Stratton Intek V...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
B/S 23 H.P. OHV Hard to turn over.
THE VALVE NEED TO BE SET TO 3 TO 5 THOUSANTHS
Apr 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
814 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
