Question about Car Audio & Video
Is the Jensen car speaker model cv 650 a 4 OHM spreaker? I'm trying to match a 4 OHM subwoofer.
  • messstat
    messstat May 11, 2010
    you don't have to match the 4ohm sub...whats your amp power the sub at?
    Problem Solver:
  • 4 Answers
It should be a 4 ohm speaker as this is the standard impedence for car audio speakers. Jensen does not produce car audio speakers with any other impedences.
Posted on Jun 23, 2009
What amp should I use?
Yes they information available on them they are still around. You will need a class-D 300 watt RMS amp to run them at perfect power if i remember right they are 150 watt RMS,, 450 watt max per sub.// just never mind the max it means nothing. They are a 4 ohm sub i believe so you would want to get a 1 ohm stable amp. two 4 ohm subs can be run at 1 ohm wired in series. they are actually made by audio vox corp.to wire them is easy ill give a link to do so easy to use. and handy. let me look for some info on your sub...? Yes there is info out there here is another link. Need additional help give a shout.
Rockford Fosgate Woofer WiringWizard JENSEN XS1010 Specs
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
Will the E-715 work at 4 ohms
They will work at 4 ohm, but you won't get near as much volume out of them as you would if you used an 8 ohm amp. The E-715 speakers are rated for 8ohms. You could damage your amp running speakers that are not matched to the same ohm rating, however it is safer to run a low ohm amp to higher ohm speakers then it is to go from low ohm speakers to a high ohm amp. Your speakers will perform how they were intended if you match the ohm rating, so try to do that at if at all possible.
Chris
Jul 16, 2011 | Cerwin Vega Cerwin-Vega E-715 Floor...
I have a lanzar max pro 15'' subwoofer and i need to know how to wire it. It has four wire inputs on each side teo positive and two negative, is this just to change it from 4 to 8 ohm or something?
In part yes it is a flexibility for wiring your speakers to match the impedance of your amp. For example if your subs are 2 ohm dvc by wiring them in parallel you can drop the impedance down to 1 ohm per speaker and if you connect two 1 ohm then you get 1/2 an ohm load. Or you can put them in series and increase the impedance to 8 ohms which I wouldn't suggest you do. Here is a link to wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 19, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
Amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Jul 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
How do i wire my audio bahn speakers to 2 or 1 ohm like i have them hooked up on 4 ohms but i wanna lower thew ohms there 2 other outlets on the speakers but how do i do it?
This is a 6 ohm speaker, which should be wired to a 6 ohm outlet, but 4 ohm outlet is working, so allow it to stay like that. If you try to connect to 2 or 1 ohm outlet, the performance will actually worsen. In electrical theory, maximum power is transferred to a load (speaker) when the impedance is a match. You already have a mis-match of 6 to 4 ohm, but it is close enough. Try not to go farther away from maximum power transfer. Your speaker will draw too much current on a 1 or 2 ohm outlet and you may end up blowing fuses, too.
Aug 06, 2007 | AudioBahn ALUM12 Car Subwoofer
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
