all sounds and looks fine but no heating going on this 5 y.o. samsung microwave. If it is door switch (any one of 3 I believe) how to check or if magnetron I'd think I'd have to throw away...Advice?
Comments:
Jun 21, 2009
- thanks for your advice on my microwave...so is there a way to test the magnetron to be sure that is it...I'll see if its under waranty, if not guess its trash...thanks so much
It's most likely the magnatron. If it sounds good it's not the switches, transformer or diode. If you still have the book for it, a lot of magnatrons are covered under warranty for 5 years. Unless it's a real nice microwave, it's usually going to cost $100 for a mag and nowdays it's almost cheaper to get a new one. Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung MW1080STA 1100 Watts
I have a Samsung SMH7177 microwave that will shut itself off after about 1 minute of cooking. The...
(More)
I have a Samsung SMH7177 microwave that will shut itself off after about 1 minute of cooking. The cooling fan no longer runs while cooking. It acts like a thermal fuse as the panel goes blank for several minutes and then resets itself. Any suggestions?
The display panel is lit up with the following: start enter cook time1 time2 8888 Kg g oz. lbs....
(More)
The display panel is lit up with the following: start enter cook time1 time2 8888 Kg g oz. lbs. Qnty. ...but nothing works when I try and use it! Any ideas?
our Orbit LG smartwave key pad doesn't register when we push the 1 or cook time. Other numbers and...
(More)
our Orbit LG smartwave key pad doesn't register when we push the 1 or cook time. Other numbers and features work. Where do we get the key pad to replace? OR do we ditch the whole thing?
How do you set the power level on a samsung microwave mw1080sta? Is the power level given as a...
(More)
How do you set the power level on a samsung microwave mw1080sta? Is the power level given as a percent or on a scale from 1 to 10?
