I replaced my control board on a kitchenaid superba stove top oven model # KGSC308LSSO and that is the error i get with the new board, my old board wont let the oven work doesnt heat up, a fix for both would be nice
SOURCE: Kitchenaid Superba gas stove. Oven
so you get an error message on the display?
do the burners work?
SOURCE: F1:E3 KGST307 free standing stove
there is no way to reset the control. you have to replace it. sounds the the jumpers on the board have failed.
SOURCE: Hi I have a Kitchenaid
Hello there:
It won't bake but it will broil please read the entire solution
Usually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.
works
only intermittently, it's probably because of worn or bad contacts in
the receptacle that the element plugs into. On most electric ranges, you
can remove the element by lifting it up several inches and firmly
pulling it away from its attachment (receptacle). Read your owner's
manual to learn the correct technique for your range.
If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If
the oven does not have a separate bake/broil/etc. selector switch, the
problem may be with the thermostat. But it's not easy to check the
selector switch or thermostat for proper operation. If you suspect a
problem in this area, call a qualified appliance repair technician.
