Question about Toshiba 24 24 in. TV/VCR/DVD Combo
Cable hook up on back
I hit the cable screw that comes out of back of tv when moving i need to replace it
i have back off and don;t know how to get that part off so i can buy a new one
  • 1,694 Answers
RCA part # 215543 or MOUSER Electronics # 61-5372 or
provide the model # off the back of tv to get tuner replacement,
and that is the cleanest fix............T.
Posted on Nov 16, 2007
  • 143 Answers
Is this completly broken off or can you salvage it it is very hard to solder one on you have to make sure that the tuner is not broken on the pc board if it is then it would be better to take it in if you still think you would like to fix it yourself then go to mat electronics on the web and find a solder typ connection k
Posted on Nov 03, 2007
  • marco amezcua
    marco amezcua Nov 03, 2007
    billcc tell me what went wrong and ill help you fix it k
My cable wont show on the tv in i do not know how to hook it back up
If you've got the wire screwed on to the connection labelled Antenna you'll need to use the remote for the next step. From the TV remote hit the MENU or SETTINGS button. Look for an option on the screen called setup or signal. Memorizing the channels would be the next step. You may need to change an option here from Antenna to Cable in the setup screen, then let the TV run through all the channels to memorize them.
Oct 04, 2015 | Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
"my olevia VCF-42FDV1U got zapped by lightning that hit an exposed cable line outside,now the power light comes on but no picture?
if just only raster then can not get any channel the tuner get bad which some parts get burned. if you don't have an idea how to replaced the parts just leave it to the trained tv technician or service shop.tuner is not too expensive unlike replacing an lcd monitor.
Aug 14, 2012 | Televison & Video
How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
Feb 16, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Cable from converter box don't fit audio holes on back of TV
you need to buy some adapter radio shack sold him
Apr 24, 2009 | Televison & Video
Curtis mathes tv - model cm25020s
had the same problem if you have any skills with soldering open it up and check on the pins on the thing in the back lefthand corner. On mine the solder has a circular crack around one of the pins that when the back was on on it pushed the chip itself up and cause that one pin to not touch. The thing i refer to is the black tower that has 2 philip type "screw" that you turn to change the defalt color or somthing like it. well hope what i said help if you have not trashed it or got a new tv... or both.
Oct 13, 2008 | Televison & Video
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Will not work with cable
The set has a problem with the tuner itself and there are no resets in this new sets,you should remove the back cover and carefully tap with a wooden or rubber handle the tuner area where the cable comes in to see if a channel would tunes in,if it does react is likely it has loose conections in the tuner grounds or pins,the conector where you screw the cable to can not be loose either,it should be nice and solid,if you are familiar with tv service is something you can try but if you are not too familiar call for assistance from a servicer or just save the money and use a vcr to change the channels using the same imput as the dvd player unless you have two separete aux.imputs. Let Us know if you need more information.
Nov 10, 2006 | Sony KV-35S45 35" TV
Toshiba 24 24 in. TV/VCR/DVD Combo Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
