Question about Refrigerators
My fridge-freezer (GE) was working fine (12 years) until today.... Now, the freezer part of it is still working but not cold enough and the food inside is defrosting.... But it is still cold.... Do you have an idea, please ?
  • jlp2311 Jun 21, 2009
    how do I check my freon pressure ?
    Sergeant:
  • 212 Answers
Need to check your freon pressure. if low then your not gonna get cold enough. you cold also have a partial restriction in your filter drier
Posted on Jun 21, 2009
  • kenrick driscoll Jun 21, 2009
    need to use a saddle valve to tap into your process tube on compressor. you have to soder this on then tap into line to be able to recieve pressure readings with proper gauges
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
GE GSS22UFPWW Fridge is not cold enough 9 is like a 1 in temp
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 27, 2008 | GE Refrigerators
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
