Question about Samsung 204T 20" LCD Monitor
Samsung Syncmaster 204T flashing
The monitor on my dual-monitor system is set to turn off after 5 minutes (to save energy and lifetime of the monitor). When I turn the sytem back on (mouse movement, etc.), the monitor flashes darkly (that is off, then dimly lit, etc.) at a high rate (10-20 times per second), slowly getting brighter in the on phase of the flash, until it is fully bright. Then it switches off. If I turn it off then back on (with the power switch) it will often stay on, without flashing, but sometimes turns off again, until I repeat that process.
It seems to me that this is some failure, and I am trying to contact Samsung about it.
  • 58 Answers
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Posted on Jun 21, 2009
Samsung syncmaster 244T. Powerlight blinks and no picture for about 5-7 minutes then steady light and monitor works fine.. Any suggestion?
monitor is power saving mode
when taking a monitor out of this mode is move the mouse or press keys on the keyboard You can buy a used from eBay for $100 or I would buy a new one for about the same price 24 inch monitors are around $100
May 14, 2018 | Samsung Computers & Internet
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Samsung 204T monitor hard to start
we need to check first the switch button, remove that and look for replacement. if still encountering problem well proceed trouble shooting ckt side.
Apr 20, 2010 | Samsung SyncMaster 204T Monitor
My son crack the LCD glass on his 204T SyncMaster
The glass of the panel is glued or welded to the LCD wafer below, it cannot be replaced separately. Since the panel is the most expensive part of an LCD monitor, its probably the cheapest option to just get a new monitor - spare part ordering and extensive manual work required for the change simply outweighs the remaining value of the monitor.
Feb 09, 2010 | Samsung SyncMaster 204t 20.1" Flat Panel...
I have a SyncMaster 204 T that the back light wont always light
Look for bad caps in the power supply first, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
report back what you see so we can guide you further.
Feb 06, 2010 | Samsung SyncMaster 204T Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
Sep 02, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung 204T 20" LCD Monitor Logo
248 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
