Question about Kenmore 63942 Dryer
Kenmore 90 series dryer screeches when starts
Kenmore dryer screeches when it starts and slowly diminshes over time to a low screech.
  • 770 Answers
The likely cause is your belt slipping. The reason it is louder when you start is just that...It pulls harder to get the tub rolling and as it gains momentum the belt doesn't have to work as hard. Your belt is worn and will eventually break. When it slips, it is wearing at a greater rate, so you may want to go ahead and replace it.
Posted on Jun 21, 2009
Squealing noise on may tag 3000 series dryer at start of cycle
There are a few causes for this. One is the main bearing, video below to show repair.
Squeaky Noisy or Screeching Dryer
Second is the drum rollers themselves, I use a heavyweight oil on the shaft and it cures it on mine for a couple years.
Fixin My Noisy Squeaking Kenmore Clothes Dryer
Mar 12, 2018 | Dryers
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
The loud screeching noise is either the belt pulley or one of the 2 wheels that support the drum. There's quite a bit of disassembly to reach them.
Aug 11, 2017 | Kenmore Dryers
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
Kenmore elile electric dryer screeches and now it wont run
Worn out. No solution to keep it running. Had a dryer I had to trash that did the very same thing........
Aug 27, 2012 | Dryers
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore Oasis drum began screeching when i started the dryer this a.m. - no problem last night. Can i fix it?
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Screeching noise when running the dryer.
Most likely source is the idler pulley. Secondly, is the drum support roller closest to the motor. If the screech is a slower frequency it's likely the roller because the support roller travels at slower speed than idler pulley. Both are replaced by raising top and removing front. Caution: Pull plug before starting and draw diagram of how the belt travels around the idler roller. You will need it to get this back on properly.
Aug 18, 2009 | Kenmore Dryers
Screeching Kenmore front loading dryer
There is a hub and bearing that needs to be replaced you will need to have this serviced by a qualified tech. The whole front of the dryer has to come off and the basket needs to be removed.
Jan 05, 2009 | Kenmore 94872 Front Load Stacked Washer /...
Kenmore 63942 Dryer Logo
217 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
