Question about HP Compaq Presario V2000 Notebook
Hi pc wont start
It wont start what can i do ?
  • 1,006 Answers
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Comment by Beni S-P, posted on Oct 26, 2007
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
And i forgot :
check power suplay and ram???Let me know if u get help???
Posted on Nov 03, 2007
Hi my lenovo g570 gives F2 and F12 options when switched on,but wont start the laptop
hit f2 finish setup, boot from hard drive
if this helps please rate with comment
Feb 02, 2013 | Computers & Internet
Wont power up
hi,
  • Replace the CMOS battery.You can first remove it and re-fix it again, start machine and observe.
  • Disconnect hard drive and then connect again.
  • Start the machine.
Hope it helps.Thanks!
Sep 28, 2011 | Medion M3 Composer 5200 PC Desktop
PC Wont Boot
hi, i suggest you check the hardwares like the RAM if u have 2 slots remove one try the other if it continues try the second on various slots. u can check the harddisk to for it to be fixed firmly
Jun 08, 2010 | Evesham Axis PC Desktop
A305-s6905 wont start up
Hi
It sounds like one of 2 things
1) The DC jack on your motherboard is loose (You can test by getting some long nose pliers and wiggling the DC jack at the back of your PC if it feels loose this jack will need to be replaced by a reputable PC repair shop
2) The motherboard/CPU itself have blown, again this will need to be booked into a reputable PC shop for replacement
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Toshiba Computers & Internet
Hi my toshiba satellite wont loaad the os... olease help me thanks.
Hi, Please be a bit specific of what OS u are running and what happened for it to start that behaviour (In otherword how did it start according to u), how does it start and where does it stop.then now we can help.
Cheers
Apr 27, 2009 | Computers & Internet
Laptop wont start up
hi dear
just press F5 before start windows, entering safe mode ....and you can try to uninstall the AVG first, after that try to re installed again
ok
cropp
Apr 12, 2009 | Computers & Internet
My video (onboard) will not start the computer starts and runs
remove the cmos battery and than start the system and are u getting any kind of beep sounds?
Nov 11, 2008 | IBM NetVista PC Desktop
Dell Latitude PPO1 laptop wont start
If the laptop is not powering on either with the battery or the Ac adapter. Its a bad motherboard and would require repair. You can contact Dell Out of warranty repairs and they would give you an estimate of the same.
Thanks
proton
Nov 08, 2008 | Dell Latitude D600 Notebook
My nana wont turn on
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
Apr 19, 2008 | Apple iPod nano
HP Compaq Presario V2000 Notebook Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
