Question about Tomtom Navigator Bluetooth GPS Receiver
I have a sat nav which I beleive uses tomtom 5 or 6 software. The unit which connects to any in car screen (so it is basically a stand alone box) has an SD card which I have programed with extra voices & POI's etc no problem & it does work quite well. I have 2 problems, I cannot get it to recognise more than 4 digit postcodes (I have all the usual software which works on my normal tomtom & many friends too) & it occasionaly refueses to forget its last destination. I.E. I get home, clear the route when I switch it back on it returns to that route ! Which at the moment is my home address. I can clear the route & even pick another route, but as soon as I switch off it goes back to directing me home, even if I'm already there ! Help would be appreciated. Thanks folks.
  • craigsouth69 Jun 22, 2009
    Hi & thanks for your responce. I am a UK resident & the unit has UK & Europe map installed. I have used all the upgrades I have done to this machine on several other tomtoms with no problems at all . I have also tried doing the postcode upgrade before doing anything else (I have a clean back up copy of the software on my pc) & I am only using a 2gb card (which came with the unit). Thanks again.
    Brigadier General:
  • 4,090 Answers
There are few things here to consider.
1) the 4 digit postcode is related to say Australia, you are using the basic fronte end of a set of maps designed for a country with 4 digits but have modified some poi's that should be in a 6 digit environment
The size of the card is beyond the ability of the unit to read, so you get errors. Use a smaller capacity card and try again.
If your GPS alllows music and photo storage, use a separarety card for these and put the orginal capacity card back for the maps
You have also programed in a starting point location.. your home. All GPS gave this feature, remove it and leave blank it will say always start from Sydney CBD.by default, unless programmed otherwise to your address.
If it continually defaults to a non standard ( your address) bthen when it is savin the information the personal info file is corrupt.
As you have fiddled with the software it will bew hard for any tech to sort out your problem.
I have this all the time on our own brand of GPS, where people change voices, put in POI's written and converted from other models or even brands and somehow corrupt the basic files.
If you have a card reader ( i am sure you do) put the card in and type part of your address in SEARCH and see which file it appears in (.data) (.txt) delete it and recreate it then try again.
Hope that helps
Posted on Jun 21, 2009
How do you go to the menu
On TomTom's Sat-Navs tap the Map if you have another Sat-Nav then im sorry i cant help you
TomTom At the Heart of the Journey - TomTom's Website
Garmin United States Home - Garmin's website
Hope i helped
AS
Aug 17, 2014 | GPS
Sat nav just stopped working today in perth wa, not picking up any sat signal. any way to fix this? is it my sat nav or the sats?
It isn't the sats. They're fine.
Try resetting the unit. Use a paper clip to press the button in a small hole on the bottom.
Try to reset the sats. To do this:
Tap the satellite bars in the lower right-hand corner.
Then, on the next screen, tap the satellite bars in the right-hand margin.
On the next screen, select "Configure." Choose a different configuration. Tap "Done," then "Done" again on the next screen.
Did that help?
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
Aug 26, 2009 | Tomtom One XL GPS Receiver
I have connected to my computer but nothing happens.
I presume that you are using the docking unit, so plug it into a usb with the tomtom turned off, then when you turn it on it should boot up the tomtom home prog.
If that doesn't work, remove any existing tomtom home prog from your PC and try again.
Download tomtom home from your CD or from the website.
If you have aquired the unit second hand it may be blocked due to security reasons.
The only way to sort it then is to mail TomTom and give them your serial number and an explanation !
Apr 23, 2009 | Tomtom GO GPS Receiver
Tomtom 700
you might want to try:
-- plug to the electrical charger, reset for 15+ secs
-- connect to the computer, download Tomtom app and try updating the application
I had a 2006 purchased go 700 and did the above and it is working much better with latest application.
Aug 12, 2008 | Tomtom GO 700 GPS Receiver
Sat nav tomtom 910
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom go 300
The tomtom GO 300 does not need an installation disk. It has firmware ( thats a sort of pre-installed software ) that is put on it at the tomtom factory. If the firmware has become corrupted it can be reinstalled or "updated" by logging on here > http://www.tomtom.com/plus/service.php?ID=17 then click the DOWNLOAD TOMTOM HOME Link. Then connect your tomtom to your computer with a USB lead. Run the TomTom-Home software you downloaded and select "UPDATE MY PRODUCT" . After that , if you don't already have one you will need a valid SD card for your tomtom containing the maps for your country and some other activation codes which you get when you purchase maps from tomtom.
Jan 25, 2008 | Tomtom GO 300 GPS Receiver
TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
Oct 22, 2007 | Tomtom ONE GPS Receiver
TomTom ONE
uninstall tomtom home from your computer & restart, then reinstall it from scratch.
This should fix it.
http://www.tomtom.com/support/support.php?ID=2
Jun 20, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom Navigator Bluetooth GPS Receiver Logo
88 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
