Question about Canon PIXMA iP4000 InkJet Photo Printer
Hi, I have a canon ip4000, I put in a photo paper card 5x7. It's now jammed. How do I get to it in order to remove it. Thanks, Ann
    Sergeant:
    Champion:
  • 253 Answers
Hi
open the door at the back of printer and move the roller in backward direction and if u want our technician support contact http://tinyurl.com/ldnuy2
Posted on Jun 21, 2009
Orange flashing 3 times
This is a paper jam error. check for any paper jammed in the printer, switch it off and open all trays, sheet feeders, duplex unit to check for any paper. if paper was jammed previously and was torn, there might be a piece of paper still stuck in it.
hope this helps!
tom
Jul 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
My pixma iP4000 doesn't work after I took out a couple of sheets of paper that had jammed in the printer.
Check very carefully for any debris left in the printer from the jam. There are photo sensores embedded in the printer that will display an error if obscurred by paper.
Jan 23, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip4000 remove print head
Hi! You may access tha manual by clicking here. Please use the set up instruction manual (2nd m,anual from the top). Thanks for visiting FixYa.com!
Jun 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
What thickness of card can my canon ip4000 printer print onto
and the answer is:
standard paper: from a5 size (148.0 x 210.0 mm / 5.83 x 8.27 inches) to legal size* (215.9 x 355.6 mm / 8.5 x 14.0 inches)
* legal-sized paper is not loadable in the cassette.
bullet_s.gif non-standard paper: from 54.0 x 86.0 mm to 215.9 x 584.2 mm (from 2.13 x 3.39 inches to 8.5 x 23 inches) in the sheet feeder; from 89.0 x 127.0 mm to 215.9 x 297.0 mm (from 3.5 x 5 inches to 8.5 x 11.69 inches) in the cassette.
bullet_s.gif others: envelopes (european dl and us com. #10)
important
do not use the following types of paper. using such paper will not only produce unsatisfactory results, but can also cause the printer to jam or malfunction.
bullet_s.gif folded, curled, or wrinkled paper
bullet_s.gif wet paper
bullet_s.gif paper that is too thin (less than 64 gsm / 17 lb)
bullet_s.gif paper that is too thick* (more than 105 gsm / 28 lb)
bullet_s.gif picture postcards
bullet_s.gif postcards affixed with photos or stickers
bullet_s.gif envelopes with a double flap
bullet_s.gif envelopes with sticker flaps
bullet_s.gif envelopes with an embossed or treated surface
bullet_s.gif any type of paper with holes (loose-leaf paper is an exception; it is printable when loaded from the sheet feeder.)
* non-canon branded paper
Hope this does it for you, please -please leave a rating...thank you kindly
May 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Paper jam error in the output does not allow printing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Paper Jam With No Paper
sensor out of alignment...with a strong light look for a black plastic sensor
Jul 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Jammed paper
open the back of the printer and do it from there..
May 09, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
93 people viewed this question
old marine
old marine
