Error Code E52 Brother HL1650 - Office Equipment & Supplies
  • 3,230 Answers
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
Posted on Jun 21, 2009
  • Maserati430 Mar 13, 2011
    Thank You, Your hint has been very helpfull, easy to use and at least 100% successfull.
    Ian from Western Germany
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
My front load washer had e59 code I replace the control board now I have e52 code
Good Afternoon Richard, thank you for your post!
An error code E52 typically relates to the speed control board or the motor itself. An experienced service technician would test these parts by measuring the resistance of the motor to distinguish exactly which part it is. This is not a typical do-it-yourself job. Personally, I would recommend reaching out to a qualified appliance repair person who will be best able to pinpoint the exact problem causing the error code. I hope this information helps to some degree.
Best regards!
Oct 19, 2013 | Frigidaire Washing Machines
I need error code for my 91 cadillac sedan de ville error code e52 .?????
Code E52 means the computer memory has been reset, usually because the battery has been disconnected or the computer has lost power.
May 15, 2013 | Cars & Trucks
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
I have a hl 7050 printer. Recently on the screen mention "Error E52". What does it mean?
That error means the fuser has gone out, could be a dead lamp, or temperature sensors. Chances are you need a new fuser if you have 50,000 or more prints on this machine. www.precisionroller.com will have a new fuser.
Jan 28, 2010 | Brother HL 7050 Laser Printer
E52 Error - Service Call Any idea what my problem is ?
Error 52 is a malfunction of the laser motor. Laser replacement is the only fix. The last one I changed cost around $80.00
Nov 25, 2009 | Brother HL 1650 Laser Printer
Message E52 Service call what does that mean? (Brother HL 7050)
Probably a fatal error. Bad Laser Unit. Try unplugging the power cord for 10 seconds.
Jan 06, 2009 | Brother HL 7050 Laser Printer
Error e52 brother
try disasemble and clean your mantenence unit
Dec 10, 2008 | Office Equipment & Supplies
485 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
