Question about Dell Inspiron 2200 Notebook
My screen seems to have rotated clockwise 90 degrees. I do not know if this is virus prolbem or just something odd that suddenly happened. I accidentally opened an email I was trying to send to junk. Shortly after that, this issue occurred. I have spoken to two different people- one in Staples and one in Best Buy who said they have seen this happen on laptops without it being a virus that caused it. Any solutions?
Try Ctrl+ALT+Up Arrow Another option is to go to Start / Control Panel / Classic View / "Intel(R) GMA Driver for mobile" / Display Settings / Uncheck Rotation / Accept Changes or OK. Good luck.
Posted on Aug 10, 2009
    Problem Solver:
  • 10 Answers
Look in the settings menu, I had is problem before. You hit a button that makes this happen.
Posted on Sep 01, 2009
  • 40 Answers
You can drag the desktop items just about any where you want. Try dragging the moved items back where you want them and drop thejm and see if that helps.
Posted on Jun 21, 2009
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I accidently press something then suddenly the display panel rotated unexpectedly! Now, I don't know what to!
Hi - you probably pressed CTRL ALT Arrow Key. On Windows XP, this will rotate your display by 90 or 180 Degrees depending on which of the four arrow keys you pressed. Just try doing the same again - that should resolve it.
Sep 15, 2010 | ASUS Eee PC 900 PC Notebook
My acer aspire one netbook display was rotated 90% counter clockwise by accident. How can I restore the display to normal
Right click on the desktop away from the icons. Scroll down untill you see something like ati or Nvidia control panel. Select that and look in the left hand side for either screen orientation or screen rotation. Choose 0 degrees or landscape.
You can also get to these settings through the control panel > display settings > Screen Orientation > Landscape.
Jun 21, 2010 | Acer Aspire One AOA110-1113 Netbook
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
I want to rotate the screen on my HTC touch VIVA, is there any software or any settings i can change, if software where do i find it
My Hermes allows me to rotate the screen using a hardware button assignment or using the HTC Home plugin. Using a 'touchflo'-like application -with no hardware button to spare- it was annoying going back to my today-screen to rotate the screen.
It turned out the Compact Framework 2.0 has this nice class which would do the trick: Microsoft.WindowsCE.Forms.SystemSettings.ScreenOri entation
So I "wrote" exactly 10 lines of code (including class/function def) to rotate my screen.
Anyone interested: download and install the cab.
+ Does not remain in memory: rotates the screen and exits
+ Now you can create a shortcut to rotate the screen
+ tested on a Hermes (TyTN)
- Requires Compact Framework 2.0 (should be default for Windows Mobile 6.0)
- CF is a huge overhead when only needed for this program, but I'm to lazy to go for the API call (ChangeDisplaySettingsEx)
- No settings: rotates 90 degrees counter clockwise (or 90 degrees clockwise with the Rotate Screen CW cab) -on my TyTN it matches the screen setting when the keyboard slides out-
- Not tested on other hardware, but I expect the worst thing that could happen is a frozen device which will work nicely after a soft-reset. My expectation is based on the fact it's a CF 'call' and not an API call, therefore it does not write to memory locations directly.
Use 'as is'.
I might be tempted to add 'settings' if people actually would use the program and have requests...
When installed on other devices: a message would be appreciated (even if is doesn't work)
Mar 10, 2010 | HTC Touch Viva Cell Phone
Screen has turned 90 degrees counter clockwise
press ctrl alt and the up arrow button at the same time and it should work fine
Jun 06, 2009 | Dell Inspiron E1705 Notebook
Screen image rotated through 90 deg.
Hello , friend
Please do this shortcut
ctrl + alt + arrow keys
Jul 26, 2008 | Lenovo ThinkPad T61 Notebook
Screen rotation
there is an icon for your screen setup on the tray.
right click on it. an option will be there in pop-up appeared for rotation. Select the right choice.. n njoy.....
thanks
iqbal
Mar 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
How can the image be rotated?
To rotate a vertical image, display the image in playback mode, press the down key to cycle through the three positions: 90 degrees counterclockwise, 90 degrees clockwise, and horizontal. Upside down position is not available.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Dell Inspiron 2200 Notebook Logo
168 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
