Question about Bose in-ear headphones - Black with black/white cord
Headphones don't stand up to normal wear and tear
I have had the right speaker cut out after a few weeks-months on every single one of the headsets and earbuds I've ever owned (at least half a dozen pairs)!!! I seems to happen faster when using a player in my pants pockets. It must be wear on the jack, but these things just are very poorly made in terms of durability. I'm VERY surprised more people don't voice this complain. My only suggestion is to avoid the damage by not carrying players in pockets with headphones attached.
dauphine
  • 207 Answers
SOURCE: My cat chewed the wiring on my Bose in-ear headphones
Of course. Just peal off the main isolation and connect wires according to color of their individual isolation. You can just twist them and wrap them with duct tape or solder them and wrap with duct tape.
My cat recently chewed trough 220 Volts stereo power cord (fortunately unplugged) and trough speakers cable too. They work perfectly again after quick fix while my room has become off-limit zone to my cat. ;-)
Better get your tomcat fixed or find him a girlfriend unless you'd like to risk him getting killed when he starts chewing some power cord.
Posted on May 10, 2008
  • 93 Answers
SOURCE: My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Posted on Feb 27, 2009
SOURCE: Humming sound in the left earpiece
Hi all,
Mine has had the same problem as the rest, and I just fixed mine. I hope this solution will work for
the rest of you also. The problem is with R82 located on the pcboard in the left ear piece. This
is a variable resistor. Inside this resistor it develops a condition called a dry contact where the
wiper isn't making contact with the conductive surface. If the pot is moved a bit then returned
to its original position, it wipes the contact clean and restores normal function. To access this
pot, remove the ear pad and fold down the cloth from the top just enough to get to the screw
that is closest to the top. After removing this screw, you can remove the arch shaped cover
on the outside. R82 is labeled. The problem is they put a drop of glue to prevent the pot from
rotating. GENTLY! remove the drop of glue. I used a sharp knife and wedged it between the
pot and the glue, do not put too much pressure on the pot. Once the glue has been removed,
not the position of the pot and turn it slightly and the return it to its original position. That is all.
For those designing circuits, make sure that you have about 1mA of current through the wiper
during normal operation. This will prevent this problem.
This may not work for you and I am not responsible for making a mess from your headphones
so try it at your own risk.
Let me know if it works.
Mark Bauer
mark@zjunk.net
Posted on Mar 21, 2009
SOURCE: My left earbud no longer produces sound!
whatever the problem is give a call to Bose customer support(800-999-2673) and u can talk with them to get a replacement. If u r in one year warranty they will replace it(even if havnt bought it at bose store)...otherwise they will charge $50 i believe
Posted on Jul 06, 2009
  • 34 Answers
SOURCE: Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Posted on Sep 19, 2009
Bose quietcomfort15 headphones
Riley, it could be that the membrane on the cone of the speaker is damaged, if that were the case, then you will have to replace the headset with a new one; also check the wiring to the speaker there may be a bad connection to the speaker, if that is the problem, it can be solved by soldering the connection back to the the speaker. you can also squeeze the cord starting from the bottom and slide your fingers up the cord, listen through the headphones for any break inn signal, if that happens,cut the wire and re-splice the wire and tape the wiring with electrical tape. good luck.
Apr 30, 2012 | Bose QuietComfort 15 Headphones
I have had my Advent Modena M202 laptop for 3 weeks now. At first the built in speakers were working, then the left speaker cut out and stopped working after 1 week, the right hand speaker has now cut out...
This could be one of two things;
  1. There is a wiring, connection issue from the laptop to the speakers.
  2. There is a driver issue. Try clicking uninstall on the speakers. Under device manager, right click the speakers and click uninstall, and then click scan for changes. This will attempt to install the newer drivers.
Mar 15, 2011 | Computers & Internet
Had about 4 pairs of the same brand of headset and after about 7 or 8 months lose hearing of sound form the left side. Always the left. their is no sign of tear in cable from out side and it cost a lot of...
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
Sep 02, 2017 | Labtec Radio Communications
Logitech cordless headphones model #A-00006 has problem with left headphone cutting out. Please help.
Hi All,
I have a
are Logitech Model # A-00006 and the wireless antenna unit is Model # A-00007.
Recently I am noticing that what is normally a stereo experience of listening while I am in on a Beacon conference call is becoming a mono experience (only the right earphone). Not sure if this is because of bandwidth fluctuations or a problem with beacon or a problem with my headset, but it doesn't seem to do it when I'm in a 1:1 call.
Odd thing is I don't hear it cutting out when I am making a direct call - only when it's a multiparty Conf call.
Thank you inadvance,
B1L
Jan 08, 2011 | Logitech (980174) Headset
The left headphone on my Plantronics Gamecom Pro 1 headset seems to not be working. Occassionally upon plugging it back in (it is USB), both headphones will work, but then the left one seems to cut out...
Most headphones are sealed by clips located underneath the foam (on the ear things). Stick a paperclip or xacto knife into the hole to unlatch the clips and then pry it outward. However, check the cable for any obvious breaks before disassembling your headphones.
Dec 31, 2010 | Plantronics GameCom Pro 1 Headset
These headphones have inexplicably gone soft, and on some models one ear goes out. We bought and used 24 pairs for our classroom literacy software but they've all died. How do I deal with this?
It sounds as if the cables are not standing up to the wear and tear of normal usage in the classroom. Try contacting the company here and asking what they can do for you:http://labtec.custhelp.com/cgi-bin/labtec.cfg/php/enduser/std_adp.php?p_faqid=1880&p_created=1103830304&p_sid=awDToaLj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xMDQsMTA0JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1 For the expenditure you have made they should help you in some way.
Oct 23, 2009 | Labtec Elite 820 - headphones
Right earplug is shorted out. sound goes in and out. how do i fix it?
The right ear plug internal wire is cut off due to wear and tear. This is common problem with earplug especially if
if you pull by the wire of your earplugs. The solution is to
cut open the wirings of your right earplug and reconnect,
resolder it, and tape the bare wires, to restore the sound. However, it will be unsighty. So, the best thing
to do is to buy another.
Oct 13, 2009 | Etymotic Research Isolator ER-6i Consumer...
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Bose  in-ear headphones - Black with black/white cord Logo
108 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
