I would advise talking to toshiba for a replacement.
If still you want to replace ir, you have to disassemble the whole laptop to replace the fan, all you have to do once disassembled is unplug the original one and plug the replacement one, but you have to use only compatible ones, or else you will burn your cpu or the fan wont fit.
For a quick resolution, buy a powerfol laptop cooler.
Cheers
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A215-S7422
I have a MSI Wind Netbook MS-N011 I have a AT&T satellite usb that plugs into the computer...
(More)
I have a MSI Wind Netbook MS-N011 I have a AT&T satellite usb that plugs into the computer downloads software to be able to internet anywhere. I have tried to use it on this one and it will no sign on. I called AT&T and they said the Wi-Fi needs to be turned off I have turned the only WI-FI I could find and it still won't work. Help!!!
I have an exisitng sat that works fine. I bought a 2nd receiver,a dual lnb and a multi switch.Where...
(More)
I have an exisitng sat that works fine. I bought a 2nd receiver,a dual lnb and a multi switch.Where exactly is the dual lnb installed?
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing....
(More)
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
