Question about Zenith P50W26 50 in. Plasma Television
Invalid format, I was going thru the various foramts on my plasma, now the screen just says invalid format, I cannot get the picture back
I have a bunker hill item 62463 dvr security system and all i get on my T.V is invalid Format it will do nothing else
You need to use the TV remote, and change the input to video, or DVR ...or something. Run through the various input channels, and you will find it. Invalid format is like if my TV is set to RGB/PC input, but the screen has timed out and is in sleep mode (no display) ...it puts invalid format on the screen. Or if you go to straight TV instead the channel that's connected to the box, same thing. You have to have the right input selected. You usually need the remote for it.
Dec 02, 2017 | Computers & Internet
I have a LG Plasma 50 inch TV, I have Roku hooked in HDMI 1, when I turn on TV the screen is black out with invalid format flashing across screen, how do I fix it.?
you will have to go into the roku settings and change the resolution to one that works with your tv
if your roku has rca jacks hook it to that temporally so you can see a picture on your tv to change the setting
Nov 13, 2017 | LG Televison & Video
PS3 start-up. ''Invalid Format'' presented on screen. Can hear sound but no picture. TV is LG Plasma Model # 60PY3D
turn off the ps3. when you turn it back on by the console hold the button down until you hear a beep, keep holding it down until you hear a second beep, this will reset the format back to normal, if you have hdmi or anything else you can change it then from your video settings menu.
Jun 20, 2010 | Sony Playstation 3 (PS3) Console
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
Invalid format
Try rechecking all wire connections for proper placement and fit too and from the tv.
Try adjusting the video format on the DVD, flip through 480p and 1080i. See which format works best with your tv. Do the same with Wii.
See if this helps.
Jun 13, 2009 | LG 42LG70 42 in. LCD HDTV
Invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
May 20, 2009 | LG 26LG30 26 in. LCD TV
INVALID FORMAT
the tv must see an input connected. try turning on the game before the tv.
Jan 06, 2009 | LG 42PX5D 42 in. Plasma HDTV
No picture
was a pvr problem,not the tv.
Nov 22, 2008 | LG DU-60PY10 60 in. Plasma HDTV
Sometimes get "invalid format" when trying to run a video from my laptop.
i feel the images may not be of the same resolution as your plasma is ready to except  check the res of the images using photo shop or any other imaging software set the res of the image to the last seen image on the screen this should be able to solve your problem
Nov 08, 2008 | LG 42PX5D 42 in. Plasma HDTV
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P50W26 50 in. Plasma Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
