Question about Kenmore Refrigerators
We have a new kenmore elite bottom freezer refrigerator and when I attached the water line it began making ice properly, BUT the dispenser for water on the front door also began a slow drip of water. It has a very small catch lip on the front door and I noticed the problem after it made a puddle on the hardwood floor. I turned the water off to avoid the slow constant drip. This means I dont have ice. Can you help and can I fix this myself?
  • altongd Jun 21, 2009
    the tech did not correctly read the question-- this has nothing to do with the ice, except that the ice and the water dispenser use the same source. The ice is fine, but if I turn the water source on the front door water dispenser leaks. It has a slow leak that drips on to the floor so I have to turn the water off to keep it from leaking. It has done this since install. It never worked correctly.
  • altongd Jun 24, 2009
    Hotrachet,
    Would the water inlet valve be bad when it is brand new- this occurred when first installed??
    The refrig is new-- but it took us over a year to build the house and the warranty started when it was delivered and is now over a year old even tho just installed----I purchased all the appliances at one time. I had to take Sears to court to get the rebate due on the appliances and while I got my money after a year-- would just as soon not ever hear their name again. Is this something I can order the part for? and install?
    Mary
    Top Expert:
  • Kenmore Master
  • 81,424 Answers
THE PROBLEM MUST BE A STUCK OPEN WATER INLET VALVE, IT IS MOST LIKELY JUST STUCK FROM NOT BEING USED (WHAT U DON'T USE U LOOSE). REPLACE THE VAVLE.
Posted on Jun 24, 2009
  • 952 Answers
I think your water inlet valve has gone bad. there are two electric solenoids for your fridge. One for the ice maker and the other one is for the dispenser. It appears that there is a leak in the valve or the solenoid may not be completely closing.
Your Kenmore Fridge is new right? why not just contact Kenmore service and tell them that there is something wrong with your unit. It shouldn't cost you a cent if your fridge is still new. If you try to fix your problem yourself, you might end up voiding your warranty...
Posted on Jun 21, 2009
  • 3,230 Answers
There are several different reasons that an Ice Maker will stop working. One is that the water valve has gone bad. It is a 120 volt valve that is at the back and bottom of the refrigerator, it is very simple to replace but you need to make sure that is the problem before you replace it. Another thing could be that the heater in the Ice Maker has gone bad, the timer motor could be bad, and there are other reasons but they all are not things that you can replace.
Good Luck!!
Thanks
After unplugging and moving how do u turn the water back on for the ice maker and dispenser
All you need to do is connect the water line to back of the unit and open the valve. Got any more info, make model?
Sep 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Will not dispense water
First remove toe panel...Under the freezer door there is a water line connection.. press in on the outer ring and pull out the water line to disconnect....get a cup to catch the water ... then press the water paddle if water comes out you have a frozen water line in the door.. it no water you have a bad water valve... let me know if it helps
Aug 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
