Question about Compaq Presario 5000 PC Desktop
COMPAQ PRESARIO COMPUTER INDICATED PRINTER SPOOLER ERROR - RESULTS: DISABLED PRINTER. UNABLE TO REINSTALL PRINTER WITHOUT SPOOLER REPAIR. WANT FREE HELP
  • 484 Answers
- Remove the printer and all drivers with it
- Then disconnect the printer
- Then power the PC off, to an actual shut down, power off condition
- Wait 30 seconds
- Turn the PC back on
- Reinstall the printer software
- plug the printer in when it tells you to do so
- try the printer now
- it should work
Posted on Jun 21, 2009
Compaq Presario states the Local Area Connection Adapter is disabled
Try re-installing the LAN driver.
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jan 25, 2013 | HEWLETT-PACKARD Compaq Presario CQ5210F...
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
I have an HP 1020 printer. I cannot undertake any operation as the words " printer spooler not running " continues to appear on the screen. I tried to delete the printer and reinstall , without...
Print spooler not running is not the printer error, it happens when the print spooler service starts working in windows, For making it enable you dont have to reinstall the drivers for the printer, as print spooler service is for every printer, even if you put another printer the result will be the same
To Enable Print Spooler Open Control Panel
Go to administrative Tools>Services (For Windows XP Users)
Control Panel\System and Security\Administrative Tools( for windows 7 users)
Open Services Find Print Spooler in the list
Right click the service and make it stop, if its already stop set it to Start and then again give prints
Double click on the service and set "Startup type to AUTOMATIC". You should now be able to get prints from your printer
Now restart your desktop/laptop and check if the service is still working by giving any test print.
Hope it will solve your issue
If you require more assistance, regarding this topic feel free to reply
Regards, BA
Jan 14, 2011 | HP LaserJet 1020 Printer
My printer icon is gone. When I try to install new printer to reinstall it, I get a message that my "print spooler service" is not working??? I went into adminstrative functions and found...
A variation of spooler error is caused by software, giving faulty instructions. Due to this another program intercepts the instructions and confuses the spooler program. It also stops your computer from adding printers, so if this is the case, disable all third-party drivers and software. To stop the error from occurring, follow the steps listed above, but instead of reinstalling the software, you will have to modify Windows' registry. This can be quite dangerous as deleting and modifying entries may just cause even more problems, but in this case, quite necessary. But,instead of blindly poking around your computer's most important files, take professional help.
Nov 23, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Compaq computer running vista trying to add a printer message local print spooler is not running I have started the print spooler through admin tools but everytime I close the control panel it must switch...
Start the simple route: uninstall and reinstall the printer and its software. If the software is old, head to the printer manufacturer's website and download the latest driver package.
Meanwhile, track back to when the print spooler worked successfully. Was there any new software installed that may have caused the problem? A possible update from Windows, perhaps?
Sep 24, 2009 | HP Compaq Presario C500t Notebook
Can't reinstall printer- ''print spooler is not working''
If you have the windows disk for it , Save everything important to disks.  Put WIndows  disk into machine and tell it to install. It will find you version and ask if you wish to repair it, Say yes.   If you have Xp pro just "Restore" computer to the date before the problem started. If you have neither one. Save you work and then reinstall everything using your backup disks.
Mar 18, 2009 | HP Computers & Internet
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Display driver problem
Try this:
START/ right click Computer goto Manage/ click Services
Here are the services I have stopped and disabled. You can right click each service and goto properties to disable them.
readyboost
superfetch
print spooler - must be re-enabled and started if you use a printer
server
computer browser
secondary logon
security center
windows error reporting
windows search
windows firewall - must be re-enabled and started to use windows firewall
Hope that works, and please rate my response if it was helpful.
Thanks and good luck
Apr 18, 2008 | HP Compaq Presario SR5350F Desktop PC...
Compaq Presario 5000 PC Desktop Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
