Question about Kitchen Ranges
Kitchen hood not venting outside
Hood in kitchen works but is not venting
  • 146 Answers
Check to see if the dapper is opening. that is piece of metal in the flue that keep the air from the outside coming in or check if there is something plugging the top part of the flue on the roof. plus you can go roof and look down and see if there is anything blocking it.
Posted on Jun 24, 2009
How do you replace?
Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
Tools Needed
  • New Range/Kitchen Hood
  • Screws
  • Screwdriver
  • Friend
  • Wiring Nuts
  • Circuit Tester
Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
Step 1 - Shut off Electricity
Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
Step 2 - Remove Old Hood
After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
Step 3 - Check Wiring
Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
Step 4 - Find the Ducts
If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
Step 5 - Wires
Open up the covering for the wiring and put the covering in a safe area for easy reach.
Step 6 - Install the New Kitchen Hood
Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
Step 7 - Route Wiring
Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
Step 8 - Tighten Screws
Finish tightening the screws in place.
Step 9 - Test
Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
We have a vented kenmore range hood that is vented thru a pipe (out the top of the hood) to the outside of the house; air comes out the top of the hood and blows into the kitchen. why is air blowing out...
Sorry to read about your problem, I hope this helps you out.
you may have a clog, in the vent pipe, not uncommon in the winter for wild things to build nest..
their is also a air damper plate, that might be stuck, this damper prevents outside air from blowing back in
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Kitchen Ranges
I would like to put my cook top on an island in the centre of my kitchen how would i vent down thru a crawl space???
Get a downdraft cook top and drill a hole. Then run the piping to the outside wall of the house and drill again and run the piping thru to the outside. They make outside wall vents like dryer vents only bigger to accommodate the bigger vent pipe. Happy crawling. It will look and work great if you get a good stove. Do your research.
Sep 01, 2010 | Electrolux Icon Downdraft Ventilation...
Dripping Water from Hood
The outside vent is not shielding water from entering
Sep 17, 2009 | Kitchen Ranges
How do i fit the flue to the wall?
The flue fits through the wall and fits to the vent on the outside, the vent should be screwed to the outside wall.
Feb 22, 2009 | Smeg KSED65X-1 Kitchen Hood
Venting hood to outside wall.
install ducting along with closing flap (so outside wind does not blow in) and power first !
Jan 25, 2009 | Jenn-Air JXT8142ADS Kitchen Hood
No suction
There is a set of blocks that are installed on the venting system to make the unit recirculate....use the manual to find them and make sure your not venting half outside and half into the kitchen.
Feb 02, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
Kitchen hood
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
Aug 22, 2007 | Whirlpool (RH3736XLS) Kitchen Hood
Kitchen Ranges Logo
150 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
