Question about Pioneer PRO-200 60" Rear Projection Television
Dark screen on a pioneer SD-P403
The screen is dark and adds a yellow tint to every thing.
    President:
  • 788 Answers
By the desciption of your symtom, I think that you may have lost the blue CRT. You may want to call a local repair servicer to have the set diagnosed. It could be as simple as the video driver on the CRT board, or it could the the CRT itself.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 21, 2009
Tv wont turn on
bad connection. if you have some electronics experience, unplug the tv and carefully open the back , remove the main bord and check for soldering using the magnifier. if you check very good , you will see a sort of small line around the soldering . that small line are bad connection , re-solder them .
Sep 15, 2009 | Pioneer PRO-200 60" Rear Projection...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red after warm up
seems you are having a problem with the black and green projectors. the best thing to do is call a repairman or sell. unless you have a buddy of a buddy that knows electric components.
Jul 28, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer projection sd-p403
The screen looks like a bad 3D movie without the glasses. Anyone know how to fix this?
Jan 01, 2008 | Pioneer PRO-200 60" Rear Projection...
SD-P403 PROJECTION MONITER RECEIVER
Most likely the switch is bad. But it could also be the relay that the switch controls... if your mechanically inclined, get back with me.
Jeff
Nov 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD P5071-K has a dark picture, though, a good one.
You didn't mention if this problem suddenly happened or has been getting dimmer over time. If it's the latter, it could be a heavy buildup of dust/soot/smoke (depending if there are smokers in the house or a wood stove, etc) or the picture tubes going bad. If the set is over 9 years old, I'd replace it with a HDTV set and not look back. If the problem occurred suddendly, then a resistor or some other component may have gone out and it again would not likely be a cheap or easy repair.
Dec 16, 2006 | Pioneer SD-P5795W 57" Rear Projection...
Yellow screen
I can only offer a guess as to what is causing this problem. The unit's LCD screen is powered by a flat ribbon cable, which can sometimes be seen from the top of the unit as the screen is sliding out. Try observing the cable as the screen is sliding out. If you can see any cracks in the cable, it needs to be replaced. Unfortunately, you will have to send it in to Pioneer to have that done. This issue is a known problem to Pioneer. If it is indeed the flex cable, they should replace it for free with a 5-7 day wait. The screen having a yellowish tint can be a sign that this cable is about to fail. I wouldnt worry about it now if you can still see your screen fine but if the screen goes out or gets worse, I would try to send it in to Pioneer to see if they will replace that cable for you. The URL of the page that explains this issue is http://www.pioneerelectronics.com/pna/v3/pg/top/cat/article/0,,2076_310069579_395713842,00.html Good luck with your unit.
Nov 08, 2006 | Pioneer AVIC-N2 Car DVD Player
Pioneer PRO-200 60" Rear Projection Television Logo
161 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
