Question about Pioneer DEH-P5900IB CD Player
Head unit wont turn on...
All the wires did touch in the back, but i connected them separately, all correct, but it wont turn on. why? its a pioneer. not sure on the model number, but the fuse isnt blown or anything. so...?
  • xbugletx8910 Sep 14, 2009
    i got it all figured out i blew a fuse in the engin fuse box.. thanks guys!!
  • lelianjustn May 11, 2010
    Which fuse did you check? There will be one at the head unit, one inside the cars fuse block and one underneath the hood in the fuse block by the battery.
    Sergeant:
    Champion:
  • 208 Answers
So there's obviosly another component you fried when the wires touched
Posted on Jun 21, 2009
Pioneer DEH1000S car stereo after removing and reinstalling, has no audio output. The display works as normal and show radio stations playing. no audio output from preamp to power unit either
Is there a mute setting or another input mode set on the tuner/preamp? If not and there are no other inputs connected to your head unit, then it appears that it is fubar.
Hopefully there is nothing wrong with your separate amp other than needing a signal to amplify.
Sep 19, 2017 | Pioneer Car Audio & Video
Pioneer head unit extremely hot.
Do you actually have a powered antenna? What do you have that blue pwr ant wire hooked up to?
Oct 09, 2014 | Car Audio & Video
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
I own a Pioneer DEH-9650 and want to connect Apple ipod touch.
Hi I was wondering were can i buy any one of these head units, i really want the Pioneer Deh-p9650. but i cant not find one place were i can buy it. i usto have the 8400mp like 6 or 7 years ago but i sold it and now i want a nother 1... i would really like to buy the Pioneer Deh-p9650mp so if any one can point me in the right direction i would be more then greatful.
thanks
DEH-P9650MP ??
Sep 14, 2009 | Car Audio & Video
Amp not staying on
Hello lyttle_matt1,
Connect a DC voltmeter between the "remote" (+) terminal and the "ground" (-) terminal on the amp. When you turn on your Pioneer, you should read 12-14V. If you get voltage for a second and then it goes away, either the incorrect wire from the head unit is connected, or the head unit remote turn-on is defective. If the voltage remains on the terminal and the amp immediately turns back off, it's possible that the remote turn-on is not supplying adequate current for the amp. To determine if that is the case, run a separate wire from a positive (+) accessory terminal (cigarette lighter or fuse box) to the amp remote terminal. If the amp then turns on and stays on, you'll need to wire a relay into the turn-on wire. The wiring for such a relay is shown here. Most any 12V SPST or SPDT relay from an auto parts store or Radio Shack will work OK.
May 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Pioneer AVIC X1R
it was the live wire whish was connected to the swich on wire as well
May 12, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer vsz 517 reciever powerd off wont come on
I have a VSX Pioneer. Somewhere either in the back of the rfeceiver or one of the speakers there is an errant wire touching the frame. Check the back of the receiver ald all of the speaker connections. The message is to protect the speaker, but can tke out a channel on the receiver if not corrected.
Apr 12, 2008 | Pioneer Audio Players & Recorders
Pioneer DEH-P5900IB CD Player Logo
544 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
