Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer front load- Can't open the door
This machine has worked great for 5yrs. I think I overloaded it with blankets. I thought the washer was done washing. Went to open the door and it would not open. No error code, as if no power. I can till water is still in the tub. I checked the wall circuit breaker and the plug it is fine. My first thought was the door lock is jammed?? Then a power problem?? I would like to know if there is a manual door release somewhere?
Take out the bleach and softener tray (it just lifts out, angle it a little) and unscrew the 4 bezel screws and take out the bezel. You will find a red or green plastic pull line that is supposed to release the door. You may have to "man-handle" the door a bit and pull hard on the line before it will release. Once you work on the door release mechanism (I had to replace the wax motor again, even though it was the "upgrade" black plunger type) I recommend shooting a little silicon spray on the white plastic moving parts of the locking mechanism to get them to move more easily.
This is true on a Maytag Neptune MAH3000AWW front loading washer. Mine is 11 years old, and had the initial wax motor work done at 7 years.
Posted on Jul 07, 2009
    Sergeant:
    Champion:
  • 208 Answers
Service repair or get into it from the top if your motavated enough it does not have a manual opener
Posted on Jun 21, 2009
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Is there an overload switch for the maytag neptune washer? if so where is it? think I overloaded my maytag neptune washer. Now it will not turn on at all.
    There are unbalance switches inside your machine that if activated can cause the symptom you describe. Try pushing the drum in all directions and do your best to center up the wash tub with the door.
    Also as the door just opens or closes there should be an audible click. No Click = no wash or door lock so no cycle can be started.
    Thanks for using FixYa.
    Kelly
    Mar 18, 2010 | Washing Machines
    Maytag neptune error code lr
    i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
    Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
    Neptune front load washer showing code LO. Door
    You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
    Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Neptune front load washer door won't lock and won't spin
    Mine did the same, we just got a $300 mother board and now it works great... Good luck.
    Sep 16, 2009 | Maytag MAH6500 Neptune Front Loading...
    My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
    Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
    http://www.servicematters.com/maytag_library/docs/16010061.pdf
    Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Error Code "od" while trying to start machine
    Could od mean overload? Reduce or actually weigh load and re-try
    Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    1,283 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
