Question about Philips Magnavox 27MS343S 27" TV
No sound I have a Nhens DTX9950 hooked up to a Panasonic TV. I can get all the local station's digital pictures but no sound. Have checked all audio settings on the TV, converter and VCR. I get sound on videos played on the VCR and on the analog channels still broadcasting. I have done a double rescan. What next?
  • jjamehouse Jun 21, 2009
    The VCR runs through the tv. That part works fine. The tv puts out sound just fine also when I tune it to analog stations. Digital stations don't. There are no apparent audio connections, i.e. no wires.
    Sergeant:
    Champion:
  • 208 Answers
So your recieving sound from the vcr but not the tv. It sounds like the tv has a problem in the audio connections
Posted on Jun 21, 2009
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
Mar 12, 2010 | Radio Shack 15-2142 Remote Control
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Nhens convertor box www.dsconter.com
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Aug 29, 2008 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 27MS343S 27" TV Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
