Question about LG 42PC3DC 42 in. Plasma HDTV
Picture selection I just hooked up my HDTV cable box, but I'm only able to get the picture in 16:9, 4:3, and two zoom options. These options leave a gray bar on both sides of the picture. I think I need to select the horizon option, but for some reason, it's not one of my options. Please tell me what I'm doing wrong. I'm using the red, green, and blue wires for the video and the red and white wires for audio, all of which were provided by my cable company. Thanks.
    Genius:
  • 2,120 Answers
If you have a motorola HD box turn off the cable box...press menu on cable box front...select 4:3 override stretch and TV type 16:9
Posted on Oct 26, 2008
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
The picture is too large, almost as if it is on zoom, so the edges of the picture are cut off. How do I fix it?
check and see if you have a zoom button on the TV remote
If your hooked to a cable box call the provider because some of the cable boxes have a setting that will cause this issue
Dec 04, 2010 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
The whole picture does not show on the screen; faces on the edge are cut off
It's one or two problems. It depends on if you're using a cable box. First try to see if your aspect ratio is on full using the JVC remote. Just Press the Aspect button. Then if it's on full and this doesn't correct the problem it may be your cable box. If it's time Warner go into the settings by pressing the settings button on the remote twice I believe tehn go to display and select the select and check each option picture size (change to normal if you have a 4:3 t.v. or stretch if you have a 16:9 (wide screen T.V.) Then go to aspect ratio and select again eih 4:3 or 16:9. If your have a hdtv cable box select output resolution and make sure there is a bulllet next to each setting for 480i, 480p, 720p and 1080i. Then exit out of the cable settings and your picture should be ok. Now if you have the hdtv package keep in mind it is normal to have the black side bars on each side of the picture only if your watching one ofthe high definition channel network that is not actual being broadcast in hdtv or recorded in hdtv.
Oct 14, 2009 | JVC AV-32D305 32" TV
Viewing area is cut off at sides
It's not your tv. It's your cable box setting. Go into settings on your cable remote and set picture size to normal and not zoom or any other setting. Also make sure your picture format is set to 16:9 on your tv. If you cannot figure how to change picture size on your cable box, contact your cable provider. Good Luck.
Nov 04, 2008 | LG 37LC7D 37 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Picture size is always too big. No matter what the zoom setting or display setting, the image borders fall outside the screen. AKAKI tech support tel # is diconnected.
there are only normally 4 options for picture size, 4:3, 16:9, 16:9 zoom and auto, unless you are using High definition. Any other settings should be found in your cable reciever box as the picture size can be altered in its settings also.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
LG 42PC3DC 42 in. Plasma HDTV Logo
49 people viewed this question
Computer Repairing
Computer Repairing
