Question about Admiral AW22 Top Load Washer
When I put bleach in the dispenser of my new Admiral washer, it pours out on the floor. Help!
    Sergeant:
    Champion:
  • 208 Answers
There should be a hose connected to the dispenser . It may have disconnected from the dispenser
Posted on Jun 21, 2009
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The bleach dispebnser looks like it has mildew in it. How do I clean it? The manual says to clean the machine put bleach in the soap dispenser but will that clean the bleach disperser? (I have never used...
Bleach is the only real mildew buster there is. Pour a small amount in that dispenser then wipe it out with a paper towel. Or if its like mine it (the dispenser) will pop out and you can put it in the dishwasher. If you use bleach, you pour in a preset amount before the wash and it will be diluted when the washer fills up.
Dec 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The next wash, after a wash load using bleach, gets a few bleach spots. After washing a load using bleach, I've tried washing a load which would not matter if bleach contaminated it. Even the 2nd load,...
I would just put the bleach into the tub while it's filling and wait till it's about half full of water before adding the clothes.
It may help to pour the bleach into the dispenser then pour water in after it to rinse it out. Some washers say to do this in the manual.
Dec 07, 2010 | Washing Machines
WHERE IS THE FABRIC SOFTENER DISPENSER
Hi!!
In same spot you put your soap or bleach, you just do it after wash cycle, right before the rinse cycle. No automatic dispenser on this one.
Don't forget to rate this post, Good Day!!
Apr 25, 2010 | Admiral AW22 Top Load Washer
Bleach leaking out bottom of washer.
Not sure what model yu have since there is none posted but sounds like the hose from the bleach reservoir has come loose.
Eric
Sep 15, 2009 | Kenmore Washing Machines
Bleach dispenser leaking
After opening the front panel, I found that the bleach hose had cracked with age and was found hanging loose. Just ordered new replacement kit.
Aug 08, 2009 | GE Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Admiral AW22 Top Load Washer Logo
46 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
