Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Malfunction code C-001A on Imagistics color copier
    Sergeant:
    Champion:
  • 253 Answers
Reinstall
have had OEM do the same on installed
Just keep level when you install them and for our technician support contact http://tinyurl.com/ldnuy2
Posted on Jun 21, 2009
Malfuntion code c-5102 for oce imagistics cm2520
C 5102 - Main motor malfunction.Check the I/U unit gears,Fuser unit gears it is a mechanical locked problem.
Feb 01, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Fittef what I pressume to be 2 new imaging units to my Bizhub C350 and a malfunction code has appeared C-001A can you tell me what the problem could be?
Sounds like one of the units may be bad as the C001A code means that the Color Imaging Unit drive motor is not turning. It would make sense that if you got this code immediately after changing an imaging unit, that if one was locked up it is now keeping the motor from turning and thus generating the code. In any case the C001A code means the color imaging unit drive motor is not turning.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 15, 2010 | Office Equipment & Supplies
Error code for BIZHUB C350 c-001A
The color development motor M6 failure, the DC Power Supply PU1 may be defective.
Feb 10, 2010 | Office Equipment & Supplies
Imagistics -Model DL460/DL550 -C-0210 malfunction
This machine is the same as a Minolta Di450/550. This code pertains to a transfer/separation corona problem. This assembly is in the unit that drops down with the release handle in the center of the machine. If you had a paper jam or were in this area for some reason you can drop this unit down and look in the area for any scraps of paper, a staple or something that is shorting it out. If not try flopping this "bed" up and down a few times. Opening and closing the front door will reset the code, at least temporarily.
Sep 22, 2009 | Office Equipment & Supplies
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 03, 2009 | Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
I have a imagistics cm3120/cm2020,,It gives me a malfunction c-0400 message,,what can i do?
type in this code on Google! Does it start up proper? Goes through its ritual of checking its parts.
Jun 27, 2008 | Office Equipment & Supplies
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
189 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
